Bane Wand Flow questions
I got a guy using a bane set up with it's OEM 3 jet wand w/ 6 flow (11002 X's 2) and he wants to get a Chosen Wand which comes with a stock 4 low set up (9502)
Because the bane system relies on low pressure(he runs 180 psi) and high('er) flow, should I set his wand up with two 9503's?
All my truckmount guys love the Chosen's 4 flow as it gets the same results as 6 flow wands wit less water (faster drying!) and I only tweak the flow for small porty guys with 2 or 3 flow total...
Thoughts?
Tried to find the answer for you no google but after asking the exact same question 4 times and getting 3 different answer. I deleted the information. I can send you a standard spraying systems flow chart and the math to modify the psi if youd like. Or go with what Google tells you i asked " what's the flow rate of a 11002 vee-jet @ 180psi spraying water" when i add spraying water the answer was the same twice
jack zerkie
What does Bain use as a blower for recovery.That would help to decide what to use. Never put down more than your unit can extract.
Thoughts?
I would stick with the six flow. With the lack of pressure, he needs more flow to flush the carpet. I like the 4 flow but I am using 350-400 psi on the portable and 500 psi on the truck. I have an old portable with a 150 PSi pump and the 4 flow on it sucks.
Good point!
I would use my truckmount Aw29
with slot glide with it and there was no difference. I used it as a porty, so there's that. Probably what Ron said.
jeffexe
jeff
I have to agree with staying with the 6 flow for flushing. I have a 200psi kleenrite small portable. I occasionally use it for highrise apartment carpets. I use the 4 flow if the carpets just need dusting. However, If they are soiled, I use 6 flow for better flushing action. I just take a couple extra dry strokes with the 6 flow.
Sutorbilt 3m...
But severely under driven
Spins at 1275 RPM max
They attempted to change the direct coupling to drive it at a higher RPM but it Just trips Breakers
We tried to run to blowers parallel and tripped breakers
Stick with 6 flow MAX
If not you will leave carpets wet for 24 hours
What a pita to lug the thing around like a porty even😏 When they say it was built like a tank, they meant it!
FredBoyle
Fred Boyle
Role
38
when my kids were little, I had a MegaCrap portable bane Clene unit collecting dust in my garage
They were watching the Telletubbies cartoon at the time and thought it was the NuNu character from the show
Wouldn’t surprise me if that defunct company sent a cease and desist to the Producers of the show
They trademarked everything and had their lawyers on speed dial
Buh Bye Bane ….
Son of a buc, it does look like a Bane🤣 Remember, if you #only
bought the Porty, you didn't qualify
to have the "Jimmy" perks, such as the logo on your truck😂😂 Oh no!!!
frank fratto
frank fratto
Buh Bye Bane ….
I just hate to see anybody in our industry go bye-bye.
FredBoyle
Fred Boyle
Role
38
Between 1988-1993 I bought 2 “truck mount” systems, a mega port and dry cleaning system
If the internet was around back then , I wouldn’t have purchased even a spotting bottle from that company
I sense a feeling of being controlled and manipulated didn't jive with your inherent Owner Op independence...
FredBoyle
Fred Boyle
Role
38
Never felt controlled, was disappointed and angered when they disallowed my use of a hose bordered ad because I didn’t use Bane Klene equipment and chemicals exclusively
It was their right because it was their cult
late 80s they had a large cleaning operation and started in janitorial
Saw their yellow page ad in my local directory so I called because I was looking to expand into carpet cleaning
I admired how they scaled their cleaning operation so I bought my first machine based on a trip to Indianapolis
Once I used a Butler , I bought one a week later and never looked back
Reminds me of the Demise of AOL
Once broadband rolled out , dial up ended by a thousands cuts
I hope you have Bob blocked otherwise it's going to be 3 days of hose border discussions...lol
Reactions: FredBoyle
FredBoyle
Fred Boyle
Role
38
Of course … and a few others
Once you take out the trash, this place cleans up nice
But he is the one butt hurt.
SteveO.......in order to be butt hurt, one must have feelings and compassion for others..... and from my view Boyle lacks that redeeming
Quality!
The only feelings and compassion he has is for himself!
Sad!
Reactions: they live
FredBoyle
Fred Boyle
Role
38
I celebrate Festivus
And this is the airing of the grievances
Merry Christmas Kenny!
Reactions: Kenny Hayes
Dang....I hit a nerve!!!
As I lie on my death bed.....my last memory will be our shithouse adventure...Merry Christmas Fred!
Although that urinal will be a close second........and the pig wit the lipstick is 3rd!
Quality!
Sad!
Or, have served time in prison.
Reactions: bob vawter
