Top Odyssey Questions
markco
mark haynes
I've have been using Odyssey since 2020
I use it for small residential homes
CRB to scrub and Odyssey to extract
Is it easy to use, I'm 62 and just had my 2nd knee replacement and wanted the easiest machine that will still do a good job? will the driver bristles bend if you let the machines weight sit on them for extended periods? I read your earlier posts (helped me make my decision) that you like "Vacaway Double Trouble" I like Vacaway Encap Green, do you think Double Trouble is better? and i'm going to use mostly microfiber pads cause I don't have a washing machine to keep cotton bonnets clean, are the microfiber or microfiber with scrub strips better with the Odyssey and do fiber pads last or just get chewed up? Sorry, I know that's a lot of Questions,,
SteamwayPro
George
VacAway Double Trouble is much better than Encap Green. I only use Encap Green at 4-5 oz 7.5 ph on light soiled residential carpet and area rugs
Double Trouble 9.5 ph I use on medium to heavy soil. It's the best for cleaning polyester. I love Double Trouble. I use it at 2 oz for most jobs. Trashed carpet 3 oz
For Rat Nasties I use VacAway Commercial Magic 12 ph. I don't use it very often but glad I have it when I need it
Adding VacAway Detonator (Peroxide) helps with coffee stains pet stains and brightening
Reactions: markco
SteamwayPro
George
You need to run Odyssey on cement driveway or sidewalk for about 10 minutes to flatten driver bristles before you use it
No driver bristles won't flatten if Odyssey sits on them
Reactions: markco
SteamwayPro
George
Fiber pads will wear out. They get thinner the more you use them. They shouldn't tear up with Odyssey but I never used a fiber pad with Odyssey. I always use a CRB
Fiber pads will scrub better than the microfiber
Use fiber pad first to scrub and then microfiber to extract
Red fiber pad or beige fiber pad. Don't use anything too aggressive on residential carpet
Reactions: markco
SteamwayPro
George
Yes Odyssey is very easy to use and easy going up and down stairs
Before you go into customers house make sure you practice on your carpet
It does have some vibration so you need to be careful around walls shelves and tables
Some bonnets grab carpet more than others and can cause more vibration
Make sure you use a good sprayer and put down enough solution to clean and lubricate fibers. Not enough solution can cause bonnet to grab carpet and cause more vibration
I don't like 10'' CRB's because they are too light to scrub with and too slow but for Area Rugs and to groom carpet after cleaning they work perfectly
I used 10'' CRB to scrub and groom and light blue Microfiber Bonnet with Odyssey to extract on that Area Rug
Reactions: frank fratto
Swani
I have an Odyssey and it works ok. It's nice for small jobs. Mine really hops depending on the bonnet I'm using, and it cleans really slow compared to my other units. It's a good 2nd machine to have, but if it's going to be your primary unit I would urge you to get either a larger TOPS machine, or even a 17" 175.
SteamwayPro
George
Do you prefer the Odyssey over a 175?
Yes but ...
Odyssey does not scrub as good as a 175
So Odyssey needs a 14'' or 15'' CRB working in conjunction with Odyssey
10'' CRB's suck. Too light for good thorough scrubbing
And a CRB just digs out so much pet hair and crap that your vacuum misses and catches it in the trays. I can't do residential without a CRB
A 175 with a fiber pad or brush will out scrub and clean Odyssey without the CRB and even with the CRB a 175 has a little more cleaning power
So 99% of the time YES I prefer Odyssey with a CRB but when cleaning Rat Nasties a 175 will clean it faster but end results will be about the same
My Hawk is a 175-300 and when I use the 300 WOW. No way a CRB can compete with the 300 and a fiber pad or brush
I'm going to keep my Hawk 175-300 on my van and use it mostly just for the Rat Nasties
I only get 1-2 a year but I will be happy to have it when I get them
Another advantage of my 13'' Hawk is I can make my 13'' into a 15'' or 17'' just by changing drivers
It's powerful enough to handle the bigger drivers
But don't even get me started about those tiny wheels on the Hawk :madder::madder::madder:
Yes but ...
My friend who went all VLM also has the 13 inch Hawk but he ordered it with the big wheels like the Swirly, which is made by Hawk. He likes it but find it small when doing large empties. I'll let him know he can get a larger driver. He also has a CRB, Phoenix and cimex.
jeffexe
jeff
I was asking the same questions about Orbital machines a couple years ago
I watched this on youtube as well as one from Excellent supply.
They helped me with my decision. Maybe they can give you some valuable information too.
Orbot vs Trinity Orbital OP Encapsulation Cleaning Machine Showdown​
SteamwayPro
George
You need to put a riser on the driver to lift machine up so it doesn't rub
My Hawk is a 175-300 so it's powerful enough to use bigger drivers
If he has a small motor on his Hawk it might not be powerful enough to handle bigger drivers
I would always use a riser for my Clarke 17, so I could run a 19" black stripping pad. It was the perfect size for a stripping tool. It didn't take long
to upgrade from the 13😂
I think his is the 1hp. Might not be powerful enough.
