8 flow with a 6GPM Cat pump
dazzle
James
I have using 4-1.5 jets at 400 psi for years and now have 4-02's. Is 400 psi still a good pressure for most cleaning or should I change it now that I am flowing more water?
TIA
TIA
What size blower do you have?
dazzle
James
4 02 jets are no problem with a 5 gpm pump and a 47 blower
Thank you Jim.
I figured it would give me the volume of water needed but thought that it would be less resistance and possibly affect my pressure.
Would I need to clean at a little higher pressure setting or would the difference be negligible?
