- Oct 22, 2012
- Name
- Ron Marriott
I am running a honda air cooled engine on my tm. It has over 5000 hours and recently started to run rough at idle and blow a little black smoke. Obviously needs a decarb. My Polish mechanical genius friiend in the shop next door recommended to run the motor until it's hot and squirt water into the intake until the motor begins to choke. You wouldn't believe the smoke that comes out. I did this several times until the engine stopped smoking. When I began, the top rpm was 3520, now it is 3640. It runs smooth at idle. He recommends to do this once a month. Let your engine run for 10-15 min. To dry out.
