CALCIUM BUILD UP IN FRESH WATER TANK
What kind of acid and how much, how long to leave it in my 100 gallon aluminum fresh water tank to get rid of build up?
Hoody
Steven Hoodlebrink
20
White Vinegar, Gallon to the 100 gal.
joe harper
joe harper
STEVE.....is exactly RIGHT....& 1 GAL is correct.........
Jimmy, use the VINEGAR 1ST......
STRONG ACIDS ...as a Last resort......
Hoody
Steven Hoodlebrink
20
Oh leave it in overnight.
joe harper
joe harper
Jimmy,
your call...?...But for less than $2.00 you can get the job done........... 8)
I put 1 quart of Vinegar in my Butlers every month...110 gal fresh water tanks...
Then just clean with it...Cleans out Chemical pump & Chemical feed guage...
Also cleans out your wand valve,hoses,jets,ect......
At that dilution, or even 1 gal....It will only have a minimal effect on your metered solutions.
I HAVE NEVER.....had to DESCALE any of my Butler Units....in 20 + years... :wink:
Shawn Forsythe
Jimmy,
If you use Hydrmaster's powder descaler, theoretically you won't have to drain the tank. This is because it uses a sequestrant for which if there is any excess would simply serve to help the cleaning process. Use it light, and repeat until desired results have taken place.
Carpet Cleaning Fool
You can find the gallon sized jugs of vinegar at wal-mart for about $2.00
R W
There is a fix for that......look in a marine catolog for a sacraficial anode??
I think thats what it's called. It's sposed to stop that "white rust" build up.
CANADA METALS
Volvo Penta Pencil Zinc Anode
Only $5.29 USD
+ Add To Project List
Product Rating: Not reviewed
Submit a Review | Read Reviews
Availability: In Stock
WM Model #: 4732434
Manuf. Part #: CM838929Z
No Hassle Guarantee
Shipping Information
Email to a Friend
By making use of sacrificial anodes you maintain the condition and extend the life of both your boat and motor.
Martyr anodes are made from high purity zinc with added catalysts to produce an "activated alloy" insuring the anode will give 100% of itself to protect your boat from corrosive action.
Martyr anodes meet ISO 9000 certification and MIL Spec 18001-J
Isn't there something I can get at Lowes/HD/Menards like a sacificial anode?
Don't they have them in hot water heaters?
Jimmy is it doing it despite having soft water? or Do you need to add a water conditioner to your home?
Hoody
Steven Hoodlebrink
20
Call a plumbing supply company, they have them.
