Can you modifiy a vac motor?
AshleyMckendree
Ashley Mckendree
Specifically can you drill/widen the orifice of a vac motor? maybe take it from 1.6 to 2.0?
Since most have a molded/cast exhaust housing, i don't think there is much gain by enlarging the Intake orifice.
The only reason I could see for it would to have "over engineering" in your favor, if say you had to put a 90 deg bend or sharper in the intake plumbing, it is better to have a 2" 90 than a 1.5" 90, so the corresponding tubing would probably have to be larger as well.
Don't overthink this Ash, your set up is good to go.
Carpet Cleaning Fool
Tried it with a boat prop once. Can't say i'd recomment it.
Dang boat never did run right after that.
Ashley;
There are new Hi-Airwatt vac motors that easily outperform what was available just a year ago.
What are you trying to accomplish?
Larry Cobb said:
Ashley;
He wants more suck, dumbass.
Sheese ...
so what are these so called new motors about
what is the lift how much cfm how many amp
forget about the air watts no one understands that anyway
snrossi
this is the motor for australian 240v . trying to add pdf not working how do you do that. if you go to ross brown sales or ametek web site they have all the info in pdf
