Looking for reviews or recommendations on anyone who has used Mytee twin turbo heater 4800 watts would you recommend and how well did it heat?
Dasay
Dan asay
To be able to use all 4800 watts, you need to plug into 2-20 amp outlets. If you are using a high performance portable, you usually need another 2-20 amp outlets or at least a 20 and a 15 depending on your machine. That's a lot of spaghetti.
Dryer plug and stove.. Have at it.. The main reason I still do Little Giant heaters even for portable work is to have instant heat.. Yes you can mess around with electric to get mediocre heat and tripping breakers gets old fast..
Make sure you ask where the circuit panel/breaker box is on each and every job.. Not if, but when you trip it.. :winky:
