marble cleaning
N
neapolitan
I have used klenzall from stonetech with not the great of results. I used the turbo at about 400 psi to rinse. Is that anything that will do a better job? thanks Kyle Albero
We will have an auction on some Magic Wand Oxyblaster here next week. My personal favorite for cleaning Marble.
But...
Most polished Marble that I run into needs cleaning AND polishing in order to look good.
SamichUSA
I run into this quite often. I run a stone restoration business here in Denver.
If memory serves Klenzall recommends Klenzal 4 for polished stone and 3 for honed. But ee have used 3 - diltued 3:1 with water with great results.
But Mikey P is absolutely right it most likely needs more than just a clean and seal.
Often times these floors are not properly maintained. The cleaning person uses a wet mop which just moves dirt around then people walk on top of that. It sounds like a clean and polish job is what's needed.
Do you know the name of the marble? Do you have any pics?
Bee Busy
Hi Josh good to see U here....I recommended Klenztone #3 privately...I don't think many of the guys here have ever heard of this product since there's no banner? LOL
alazo1
I would just boost the klenzall with floor stripper or something similiar.
I think there's a bit of confusion.
Klenzall by stonetech and Klenztone are 2 different products. Though I've used Klenztone 3 and think it's a good cleaner, I would not have it in the truck if I had a multi truck business. Too much that you have to watch out for, glass, granite, ceramic tile and stainless to name a few. I almost used it the other day on a travertine floor. It would have probably done great except at the last minute I remembered that it would jack up the granite inserts. I don't even trust myself with it and truthfully :lol:
Albert
For cleaning use Spinergy Stone Perfect. Also increase your pressure to about 650 or 700 PSI to get effective cleaning.
As several others have stated, there is a good chance it needs more than cleaning to look good. Polishing, maybe more.
