O.P. machine comparison
richard
Do any of you OP users have any experience with the new Orbot. If so do you know if it as aggressive as a Brute or Clark machine? I have an Easy Glide but am thinking I want something with a tank/sprayer on it.
I have an Easy Glide I mainly use for post padding after HWE as well as OP extraction on cgd. I did an empty trash rental last week with the Easy Glide. I was not all that impressed with the results so I fired up the TM to finish the job. I am not too experienced in OP residential so I am assuming I could have done something different to get closer to TM results.
I would like to OP residential more often, just not too confident in the process - again I'm no OP expert yet.
Any knowledge or thoughts on OP machine comparison?
i'm no OP expert either, and have no first hand experience with the Orbot.
I do have some experience with OP though.
the truth is, forget about it for "trashed" apts or heavy soil res.
You'll never be happy with the results if you care about quality and own and run a TM now.
That's of coarse "IF" you use good chems and KNOW HOW to clean well with a TM.
(you might be surpised how many DON'T know how to clean w/TM)
...L.T.A.
Curtis Pennington
Long time ago i had a challenger and the older CCS...I liked the challenger the best.
Expect the exact same results from any of the new Wheels On The Ground OP machines.
It's the chems, pads and skill that will make a difference.
richard
For those of you who have not seen Vince in person:
If you've seen Forest Gump, you've seen Vince.
Have patience with him - he is a bit mentally undeveloped. Dumb as a rock.
Wow, he's smarter than I gave him credit for! :p
vincent
Vincent Sapp
:shock:
