I'll just for the fun of it it turns out they didn't have 35% but rather 27%.. so you can all start over
1:1 will give you 13.5%I'll just for the fun of it it turns out they didn't have 35% but rather 27%.. so you can all start over
Simple 1;1 ratio, gives you a 13.5 % solution....I'll just for the fun of it it turns out they didn't have 35% but rather 27%.. so you can all start over
Damn Fred, you beat me to it..1:1 will give you 13.5%
Re-CalculatingI'll just for the fun of it it turns out they didn't have 35% but rather 27%.. so you can all start over
Damon, the whole purpose for using purified water is so the peroxide doesn’t lose its strength. It doesn’t really matter if you use it within an hr or 2 of mixing, but if you want to store the solution beyond that, using regular water will make it degrade much faster. The unstable molecules in the peroxide will attack the impurities in the water (biological or mineral), and turn into plain water, rendering it useless....You guys overthink everything. I've been using pool peroxide for awhile now. Just put about 1/2 oz - 1oz in a bottle then top it off. No issues ever. I also store it for weeks without losing strength or using distilled water. Is your swimming pool full of distilled water?
It did do an amazing job on a human urine jobber I did. Made all the yellow go away.
liquidOk Ok so is this pool peroxide a liquid or powder??
Will the pool place nose what I want if I say Hey I need some pool peroxide?
At what quantity does 35% do anything for a typical back yard pool?
dont put it in your hot tub to find outAt what quantity does 35% do anything for a typical back yard pool?
it should last couple weeks with most tap waterYou guys overthink everything. I've been using pool peroxide for awhile now. Just put about 1/2 oz - 1oz in a bottle then top it off. No issues ever. I also store it for weeks without losing strength or using distilled water. Is your swimming pool full of distilled water?
