If you hire people to do the cleaning, that is..
You can go down at least two levels in education in your workers.
It takes a certain mental capacity and mechanical ability to run a truckmount and wand/RE/Zipper.
Right from left, up from down, red from green, gravity, on/off, wet/dry, positive/negative so on and so forth are all needed skills to clean carpet with HWE.
So figure minimum of $18 and hour for this guy..
If a guy can push a lawn mower he can run a OP/CIMEX/CRB..
$12 an hour.
Right?
$12 an hour.
Right?
