Victoria H
- Nov 21, 2023
- Name
- Victoria Heaberlin
Up for auction to start off the new year!
One 40-pound Pail of Saiger's Code Red Pre-Spray (The Beast of Pre-Sprays), Retail value: $254.37
One Gallon Saiger's NEW Mango Citrus Cide Odor Eliminator (A Party In A Bottle), Retail value: $47.02
Saiger’s “Cide” Sauce MANGO Citrus Odor Destroyer
We started with a simple goal to develop a true odor eliminator that would leave behind a light pleasant scent and positive impact with our clients.
After extensive research, we’re excited to introduce Saiger’s “Cide” Sauce MANGO Citrus Odor Destroyer– the latest technology in odor destruction!
It absorbs, modifies, destroys and safely eliminates the worst odors from Urine, Vomit, Skunk Spray, Garbage, Must/Mildew, Smoke, Sewer backup, Organic decay, Cooking odors, and many more…
Pleasant odor elimination has finally arrived! Give it a try…your clients will thank you!
DIRECTIONS
- Prepare a solution of 8 oz. per gallon of water (1 part of Saiger’s Cide to 16 parts of water) and flood the contaminated area sufficiently to soak the surface where the odor may have migrated.
- Wait 10 minutes dwell time; if possible allow to dry before cleaning.
- If the cleaning will be done at the time of treatment, apply product to the dry carpet prior to any cleaning and re-moisten surface fibers with Saiger’s Cide after the cleaning.
Pet bed, upholstery and mattresses treatment: dilute up to 6 oz. per gallon of water and spray mist the surface of fabric and brush gently and allow to dry before using.
General Cleaning solution: dilute up to 2 - 4 oz. of Saiger’s Cide per gallon of cleaning solution and proceed with normal cleaning to eliminate odors and freshen up areas.
ULV fogging: 4 oz. per gallon of water
A Great addition to Saiger’s Sauce unscented cleaning formulas!
Fragrance Boost to Pre-spray: Hydro Force Type Injection Sprayer – Dilute 2 to 8 ounces of Saiger’s Cide per 5 quart container with your Saiger’s Sauce prespray of your choice. It will give a very Fresh MANGO Citrus scent with odor eliminating capabilities.
Pump up or Electric – Dilute 2-4 ounces per gallon of mixed cleaning Saiger’s Sauce prespray of choice)
View: https://youtube.com/shorts/SWajCo_tFMw?si=qrGacq8_xjC66wUm
Saiger's Sauce Code Red combines Oxy and Enzyme to the already awesome Saiger's Sauce 1. This unscented formula allows for the addition of deodorizers such as the new Saiger's Cide Lime Citron odor destroyer.
Directions and Suggested use
Be sure to mix with warm to hot and preferably “soft” water. Don't store more than you need onyour (hot) truck.
Pump up or Electric Sprayer
1 scoop (2ounces) to 1.5 scoops (3 ounces) of Saiger’s Sauce 1 per gallon of warm to hot water. Severelysoiled carpets may require up to 3-4 ounces per gallon. Test first so you don't waste this valuable
solution.
Dilute 8 –9 scoops Saiger’s Code Red (16-18 ounces) per 5 quart container with warm to hot water, and meterat 8:1 setting. If not using a metering tip, it is typically at 4:1 setting: THEN dilute only 4-5 scoops which is 8-10 ounces of Saiger’s Code Red.
View: https://youtube.com/shorts/N_rOEFT-9Hc?si=Yhoc_cqLthliIaxi
Total Auction Value with Free Shipping to the lower 48: $301.39
Starting bid $225
Minimum bid increment $5
Auction ends Monday January 6th at 9PM EST/ 6PM PST
Starting bid $225
