Short replacement hoses for the TM?
Jim Williams
Jim Williams
What's everybody doing for replacement TM hoses? Do you just order a 50' section of solution hose and have NAPA cut it into small pieces and put ends on it? How about stainless automotive hose? Where would a man go to get something of this nature?
I have a hose and fitting shop do custom lengths for me. Supply lines and that sort of thing. I buy stainless brake line and flare fittings for wand line replacement at automotive stores.
Reactions: Jim Williams
down the road from you...
KevinD
Kevin Dumas
If you have a Tractor Supply store near you they have a line of ready made hydraulic hoses that hold up real well.
Both 1/4" and 3/8" hoses from 18 inch up to I forget how long they make them, maybe 60 inches.
Hack Attack
Dan
commercial marine supply places also carry ready made
before I was able to crimp my own, that's what I did
Jim Williams
Jim Williams
Thanks, I do have a Tractor Supply nearby. I’ll give them a try.
Fluid dynamic are very different between hot oil which don't vary, and water.
Water, as heated and pressurized becomes superheated steam and changes characteristics, sometimes dangerously.
KevinD
Kevin Dumas
The brand of hydraulic hose Tractor supply carries is a 100R2AT hose which has a petroleum and water based fluid rating.
I was a little leery of the 1st one I put on my truckmount but the 1st one I put on was from the heat exchanger to the front panel and gets the most heat and abuse. It is still there, years later along with all the others I have put on.
