Total_Rookie
- Jan 28, 2013
- Name
- Joseph Torrez
Would you buy a Square Scrub to strip wax? I know there are several ways, of getting good results. But whats the absolute easiest and most preferred way?
What system were you using admiral? I was thinking the same thing too. "Of tapping out" it seems like too much work. I just didn't want to skip before really looking at the big picture. So far it looks like an ugly picture.Tap out.
Before you choke.
Different markets are ...different.The numbers aren't there. (In real life.)
The BB world is a different story
I have to think our markets are VERY similar.I hate it and need to charge more.....or get out.
Good to hear you're getting good money for it Russ. I may contact you.
I have a Betco Square Scrub and I love it, it's a very aggressive machine. You can dry strip with it but you will need a vac system , the dust is just like dry wall dust. The only time I dry strip with it is when it's a floor that I have already done , then I know what to expect in how many layers of wax.Would you buy a Square Scrub to strip wax? I know there are several ways, of getting good results. But whats the absolute easiest and most preferred way?
We don't do much with floors. We have the equipment, just no desire at this point. I do appreciate those that are good at the craft though.Thanks. It's an interesting process bc CPC compound helps protect the finish from getting imbedded dirt. Then the Floor Prep actually opens the pores of the wax and pulls the dirt out without losing any finish.
What products do you currently use?
We don't do much with floors. We have the equipment, just no desire at this point. I do appreciate those that are good at the craft though.![]()
Bulletin BoardThat's understandable. Like a few others in this thread a lot of people are fed up with floors in general. What's your main focus then? Carpets?
You can find us at www.simplefloorcare.comI'm looking into simple floor care on Google
I have a few friends in that business. Seems to be a good industry that's thriving right now. I hope your busy and stay that way!85% Fire & Water damage restoration
It looks REALLY interesting, if it does what it claims to. I go into some real VCT messes sometimes. Is it good for that?You can find us at www.simplefloorcare.com
Maybe so. I sold my (2) powerflite portys. They were a BEAR to wrestle with alone. Especially when you add mop buckets and 175's.Instead of a wet vac to remove the slurry from stripping, I use a portable to rinse using a neutral rinse and a hard surface (gecko) tool. Much better than mopping.
How do you get all that gunk out, the wax is messy I suppose?Instead of a wet vac to remove the slurry from stripping, I use a portable to rinse using a neutral rinse and a hard surface (gecko) tool. Much better than mopping.
