What would you change about it, if you could?
Did you know some LVP flooring scratches from rough Teflon?just use your carpet wand already
*actually maybe a carpet wand with narrower angle jets and an offset overlap on those jets? As @Old Coastie said about SS vid, streaky tiles aint satisfying
sandpaper... its cheapDid you know some LVP flooring scratches from rough Teflon?
Cheap LVP has a "wear layer" that is the equivalent of a coat of vct wax...
fo-reel scratches or "scuffs" a rotary and bonnet would remove?
.L.T.A.
We'd like to think of ourselves as reasonable men:What would you change about it, if you could?
Yes. Learned that after thinking I was safe on all since it worked fine in NashvilleDid you know some LVP flooring scratches from rough Teflon?
