Thanks Zalan Szabo (zee)
ascrubabove
Got your Fels Naptha liquid sample and have used it several times with great success, thanks alot, so I poked around and found the bar, tried it and found it to be a little more handy than the liquid, but anyone who would rather use the liquid Zalan's stuff works great on those little black greasey spots you find while cleaning!
Zee
Sure thing!
I'm glad you liked it! If you get tired of the bar you can always get more of my stuff.
Scott Rogers
i think i got some of it. Came in a box with no return address label, bottle with a few styro peanuts. No marking on the bottle and no paper work inside box. Wasnt sure what it was. LOL .
I assume you use this straight no diluting? Do you sell it? If so how much. What type of spots does it work best on?
Zee
Yes Scott, it is my stuff i mix up.
You requested that I send you a sample :) I apologize- I forgot to put instructions in a lot of the boxes.
Yes you use it straight up- no dilution required. I try it on almost anything! Usually if my prespray doesn't do the trick, then that gel is my go to stuff! A lot of mystery spots had been taken care of with this gel.
It needs to be shaken up before use.
I recommend rinsing it out right away.
You can get it from me- PM me if you would like to buy more of it.
Zee
KevinL
Kevin Leach
I'll say thanks again Zee. I haven't tried it yet but I will. Nice talking to you. I did a reverse look-up on the address and found Zee's place to call. I couldn't figure out what it was either. i can't wait to try it.
