The other Big Green Machines
PXL_20210908_010552342.PORTRAIT.jpgPXL_20210908_011150884.jpgPXL_20210908_010943330.jpgPXL_20210908_010727267.jpg
What's the difference between the 3-machines?
All the stats are there but in a nutshell the grumpy is commercial only with its 140 plus pounds and your best choice if you're going to do some stone work and extremely smooth runner.
The Phoenix is light enough to throw in the truck without a ramp and can do residential and plenty of commercial with the same size motor by the much lighter weight frame than the Grumpy.
And the 69 lb darling is the Odyssey with no spray system and is ideal for residential and small commercial is it forces you to rely on dwell time rather than wait and agitation so it's safer on more delicate piles and is the only Wheels have op that you can move in either direction without having to change which direction you're facing.
Trip Moses
IMOL
Trip Moses
I can see an odyssey in my future. Is there a vid anywhere of some yahoo using it?
