Auction includes:
Saiger's Sauce is a high-performing pre-spray designed to be your "Blue Bullet" for all your carpet cleaning jobs. It's strong enough to power through greasy commercial jobs in restaurants, hotels, and retail stores, but it’s also gentle enough for routine cleaning of lightly soiled residential carpet. Whether you’re cleaning a filthy rental property or a high-end residence, Saiger’s Sauce 1 is your #1 go-to product. It even works on the most stubborn, stuck-on grease and grime on tile and grout, synthetic rugs, garage floors, and stone patios. It rinses easily and completely and won't leave behind unsightly white powder on grout lines. This non-toxic, enviro-safe formula contains no d-limonene, no butyls, no solvents, no oxidizers, and no NTA. It has a pleasant fresh lemon scent that fights odors and lingers after the cleaning is complete, leaving a positive, fresh-smelling impression on your customers.
Saiger's 10 Below was a 3 year project to create the perfect safer cleaning formula that packs a punch for cleaning of Carpets, Tile and Grout and Upholstery. (Not recommended for fine fabric upholstery). With the Saiger families relentless field testing, 10 below has emerged from the cold northern climates! Take your cleaning out of the Ice Ages with the new warranty safe and safer cleaning agent!
ODOR OXY is a unique high powered Peroxide formula with a true Odor Destroyer! Not a masking agent, but a product meant to go after the urine and odor causing organic stains! With the power of Peroxide and our unique Odor Destroyer. Designed for those cleaners who do not have the time for enzyme activation, and need quick fast results! Odor & Stain elimination oxidizers that will remove organic stains including pet urine, blood, coffee, vomit, and more. A unique formula to eliminate unpleasant stains and odors in carpet, upholstery and other fabrics. Avoid using on Wool and Silk materials, and be cautious with natural fibers.
View: https://youtu.be/pPvkycfL8rI?si=xhcaaz9k1BA4zPxp
$329.38 retail value with Free shipping to the lower 48
Starting bid $240
Minimum bid increment $2
Auction ends Thursday November 9th at 9PM EST/ 6PM PST
- One Case of the original! Our Saiger's Sauce 1 Pre-spray that started it all
- One 6.5 pound tub of Saiger's 10 Below Pre-spray
- One Case of our new Saiger's OdorOxy peroxide based stain and odor eliminator with special Saiger's Cide Mango Burst Scentsation odor eliminator
- Free shipping to lower 48
Odor Elimination with the Power of Peroxide and a True Odor Destroyer!
ODOR OXY is a unique high powered Peroxide formula with a true Odor Destroyer! Not a masking agent, but a product meant to go after the urine and odor causing organic stains! With the power of Peroxide and our unique Odor Destroyer. Designed for those cleaners who do not have the time for enzyme activation, and need quick fast results! Odor & Stain elimination oxidizers that will remove organic stains including pet urine, blood, coffee, vomit, and more. A unique formula to eliminate unpleasant stains and odors in carpet, upholstery and other fabrics. Avoid using on Wool and Silk materials, and be cautious with natural fibers.View: https://youtu.be/pPvkycfL8rI?si=xhcaaz9k1BA4zPxp
Starting bid $240
