The Vacuum's static was shocking me today.
Any cure to this defect on some of these vacuums? I turn the vacuum on...it doesn't shock. I turn the beater bar on...it's constantly shocking me from the friction.
Is there a loose wire somewhere?
Could be dangerous Matt. Have it checked out.
That's why I asked you guys. I'm not driving to a vacuum repair store. Screw that. This vacuum that's building up all that static is the Proteam upright. Has anyone else experienced that when they turn on the beater bar?
Probably not static.
Only experienced it once
a movie theater lobby with wool carpet
only happened there the day I ran it.
Never happened before or after with that same Shark vac :headscratch:
Not static. There is a two way throw for the switch and separate wiring for the beater brush. Something shorting there.
if your hair is not raising and its painful, thats usually a short from on the ac side... if your hair raises, you could be generating a charge between the carpet and brushroll.. still they try to ground that out as well..
My hair was rising.
And today, I was on a low pile carpet and it didn’t produce that static. It was just on that flimsy, 1980’s brown carpet yesterday
Thoughts and Prayers.
Now off to Jack-In-The-Box. I need some bacon cheese potato wedges.
Old Coastie
Stephen
Plug it in to a GFCI outlet. If it trips, you know the machine is buggered. If not, it’s just the static on that day or on that rug.
The outlet I plugged it into today was a gfci. It didn’t trip and it wasn’t static
It’s happened more than once on those jobs like yesterday.
It’s a sign you’re soon to be taken out by a bolt of lightning.
Ok ok. I’ll take it apart this weekend and tighten all the wires
