I did a FB Webinar tonight were I discussed many products and services..
Here are links to many of the products and some videos of the techniques in action..
http://www.groundfloor.org/ecommerce/glass-and-metal-magic.html
http://www.groundfloor.org/ecommerce/soap-scum-magic.html
----Work in progress---
http://interlinksupply.com/index.php?item_num=CC21A
http://interlinksupply.com/index.php?item_num=AB113
http://www.homedepot.com/p/Husky-2-36-in-Medium-Folding-Utility-Knife-008-044-HKY/100646860
Extra blades- 100 packs available
http://www.homedepot.com/p/Total-Reach-10-in-Grout-Brush-962170/203177367
http://www.homedepot.com/p/Master-M...scape-Lawn-Edging-with-Stakes-93016/202815090
http://www.homedepot.com/p/Stanley-...ity-Mini-Razor-Blade-Scraper-28-100/203743502 get extra blades
http://www.homedepot.com/p/Rubberma...each-Microfiber-Mopping-Kit-1887083/204630109 get 5 extra blue micro fiber mop heads
http://www.homedepot.com/p/Husky-Precision-Pick-and-Probe-Set-4-Piece-60004H/204314893
http://www.homedepot.com/p/DEWALT-Wood-Chisel-Set-4-Piece-DWHT16063/202719121
Blue painters tape and Gorilla tap form Home Depot
White, hogs hair,red and black 3M pads for your 175 and for the 7" Makita Polisher listed below..
http://www.amazon.com/Woodstock-D3390-Pick-Set-6-Piece/dp/B000OSB8T0/ref=sr_1_4?ie=UTF8&qid=1439582342&sr=8-4&keywords=dental+picks
http://www.amazon.com/Shamrock-83014-XL-bx-Industrial-Nitrile-Rubber/dp/B013SLH9FQ/ref=sr_1_4?ie=UTF8&qid=1439582639&sr=8-4&keywords=black+mechanic+gloves
http://www.homedepot.com/p/QEP-Hand...Stripping-and-Removing-Grout-10012Q/100001353
http://www.homedepot.com/p/QEP-Grout-Removal-Tool-with-Durable-Carbide-Tips-10020Q/100194652
http://www.homedepot.com/p/Shur-Line-9-in-Tear-Resistant-Deck-Painter-Pad-3955108/202080286
http://www.homedepot.com/p/Homax-4-0-12-Pad-Steel-Wool-Super-Fine-Grade-10120000/100212006
http://www.homedepot.com/p/Scotch-Brite-Extreme-Scrub-Scour-Pad-2-Pack-77222/205910382
http://www.easystonecare.com/Makita-9227C-Variable-Speed-Marble-Polisher-p/mkp.htm
interlinksupply.com
interlinksupply.com
HDX 9 in. Heavy Duty Professional Caulk Gun HD138C - The Home Depot
The HDX 13:1 Professional Caulk Gun is designed to hold standard size 10 oz. tubes. The gun is made with steel and has an aluminum alloy handle and trigger to ensure strength. It has an ergonomic trigger
www.homedepot.com
HDX Stainless Mini Brushes (3-Pack)-SMB3-HDX - The Home Depot
Clean tight spaces with these 1/2 in. Mini Brushes (3-Pack). This pack features 3-brushes with stainless steel bristles for a variety of applications and are designed with solvent and chemical-resistant
www.homedepot.com
Home | Carpet Cleaning Restoration Equipment & Supplies
Interlink Supply is #1 for Professional Carpet Cleaning & Restoration Equipment, Chemicals & Supplies! Order Online or Call 800-660-5803
