Mar 8, 2018 #1 Josh Almanza Member Cleaning Professional Joined Nov 22, 2016 Messages 193 Name Josh Almanza I’m using a hydro force to put down my ps and using with the yellow tip(8:1) seems I’m using a lot of ps to mix at this ratio(8-9scoops) will removing the yellow tip save on my chemical usage?
Mar 8, 2018 #2 Andy Member Cleaning Professional Joined Feb 5, 2016 Messages 970 Name Doesn't Matter removing the metering tip changes your ratio to 4 to 1
Mar 8, 2018 #3 hogjowl Idiot™ Cleaning Professional Joined Oct 7, 2006 Messages 50,044 The answer to you’re question is NO. Reactions: J Scott W
Mar 8, 2018 #4 dealtimeman Everyday is Saturday. Cleaning Professional Joined Sep 20, 2008 Messages 10,878 Name Michael No it will increase if you keep outing the same amount of Chem into hf.
