Turn the Cat pump around for easier access to drain and sight window as well as to assure that the clutch bolt does not back out.
Add a valve the directs ZEN or Fresh Tank water with the turn of a dial to a pressure line for Hydroforce use.
Reconfigure the lay out for more floor room and storage space and shelving.
Move the new bigger control panel over to the right for easy access to the plumbing behind it.
A bigger round Lint filter basket.
Pre installed carpet kit.
A 2 inch higher rear step so it doesn't scrape on steep roads/ drive ways.
More insulation on HX's and exhaust pipe for quicker heat.
