100% VLM ???
NO, I don't run in your circles, I've heard of it now.
Circles....EXACTLY.....OR MORE commonly known as orbits!
I really thought EVERYONE has heard of this by now......we've been tracking this interstellar object close to a year now.....
PURPOSE:UNKNOWN
However my belief is.....they have to eradicate this pesky species that are about to introduce a radioactive substance into an otherwise perfect creation......
AND MORE-FURTHER......YOU....should realize if you haven't learned of this phenomenon......how many other Things are you un-aware of????????
And yet even further more...let's say this really does exist AND have beings wit billions of years of intelligence and technology......what does that do to the Jesus story?
Yep starting to likeVLM can't pull the hoses in anymore trying to to sell truckmount van and other equipment I was doing good for a while but have run out of steam not in the truck but ME hope to make it to January to 84 so I'll just do small jobs to help pay bill.No retirement but in stock market and NOT good there but there is light at the end of the tunnel. I just have to find the tunnel.
Stud
SteamwayPro
George
Not gonna start this debate all over again, but if you hwe, you know you didn't have to #flood most carpet to get it clean. Chems and agitation are doing the same thing you're doing following up with an additional step. Some don't do that🤷🏼‍♂️
You should know by now I take a jab at HWE every chance I get :biggrin:
I did this job today. One chair, 2 Bedrooms, Hall, Living Room. I used 3 gallons for all of that. I rinsed the chair with water and that is not included. I haven't been HWE for 6 years now so I don't really remember how many gallons it would take to do that using the HWE Method but I do know it would take many more gallons than 3
How many more gallons 10 ??? 15 ??? I don't know but compared to VLM, HWE uses and WASTES many many more gallons of water
That carpet is a cheap Polyester. I used 2 oz VacAway Double Trouble and 4 oz Detonator (Peroxide) per gallon on chair and carpet
I'm starting to like that Sapphire Portable Upholstery tool. It uses too much water but adding a shut off solves that problem
LESS water MORE agitation !!!
Reactions: royalkid
SteamwayPro
George
I remember you liked and were using Carpet Details
Are you using Carpet Details with VLM
I rarely use it anymore. It just doesn't clean polyester good enough for me
If your new to VLM VacAway or Excellent Supply sell the BEST encaps
jessi
Jessi Lopez
Yes I leave the MESSY Look and I like it
If I thought there was something wrong with the MESSY Look I wouldn't post pictures
I don't worry about perfect groom lines. When the customer starts walking on the carpet those lines will disappear fast. They're not deep lines
I use a 10'' CRB with soft brushes. That carpet is thick nylon and the lines are mostly just on the surface because the CRB is light and has soft brushes. A carpet brush/rake leaves deeper lines than a 10'' CRB with soft brushes. A 10'' CRB grooms the carpet better than a Brush or Rake. My opinion
I never get any negative comments from customers but do get criticism from other cleaners. If I start getting negative comments from customers that's when I will change my opinion on the MESSY Look
I'm more concerned with getting the carpet clean and dry than groom lines
I like the MESSY Look !!!
Stretch this carpet
View attachment 133018View attachment 133016
What’s that tube on the back of that portable? Some exhaust muffler thingy to help catch all the crap air exhaust that comes out of that machine into the customer’s air???
Reactions: KevinL
SteamwayPro
George
It's a muffler that catches noise
Without the muffler it's loud and very annoying
With the muffler it's probably 50% quieter
When I'm prespraying and scrubbing furniture I have machine off
I only have the machine running when I'm extracting
I like that Sapphire Portable Upholstery Tool
Meter Maid
The Undetective
If I thoroughly scrub and then rinse carpet, use a clean white pad after the rinse and said pad is mildly dirty, then what’s the difference if I only pad that particular carpet and keep cleaning with fresh pads until the white pads are only mildly dirty, just like if I had padded it after rinsing?
Is that carpet somehow cleaner if I rinse, even though the final pad used after rinsing looks exactly like the final pad I used if I had padded that carpet only?
Because it's not different than wiping your ass. You can keep wiping with that TP and it'll still smell like crap and and make the TP look mildly dirty. But if you get your ass in the shower or use. a bidet, you'll have a clean ass.
now for your comparison with wiping the carpet after the rinse: If you're getting a dirty pad after HWE, you're not HWE correctly, or your tm isn't putting out the correct flow of water at a temp hot enough to properly rinse the carpet.
But I don't care what you guys do to your customer's carpet. Keep wiping it if it makes you feel better.
they live
Most cleaners dont make enough passes to thoroughly rinse all the soils out especially in heavily soiled carpet. That goes for padders too.
Not using enough detergent is another issue from my experience.
SteamwayPro
George
What happens to the dirt left behind ???
No Method removes 100% of the dirt and dirty water
So what happens to what's left behind
VLM uses agitation to clean with and usually dries in 1-2 hours. Dirt gets encapsulated in a detergent and crystallizes after drying and leaves no sticky residue
HWE uses WATER PRESSURE to clean with and uses at least 5 times more water than VLM. HWE usually takes 2-5 hours to dry (if customer is lucky that day) and uses a prespray and detergent
The longer it takes to dry the more dirty water left behind. VERY TRUE !!!
So what happens to all that prespray detergent and dirt left behind after it eventually dries
WATER PRESSURE pushes dirt down deeper to the bottom of the carpet making it much harder to remove, (thicker carpet much more of a problem) does the dirt detergent prespray left behind dry and remain at the bottom of the carpet, does the prespray detergent remaining at the bottom of the carpet cause resoiling, does the dirt after drying just sit at the bottom of the carpet forever, in the worst case does the dirt wick up and cause dull dingy looking carpet, or does it all just magically disappear
So what happens to all the dirt, prespray and detergent left behind by HWE
Reactions: frank fratto
they live
Only padding doesnt raise the sand and grit from the backing. Vacuuming it once wont get it all out neither.
The water is the carrier that can rinse it away most efficiently.
Not just sand and dirt but spills and oils too. It just gets deeper Imo.
Do you use a washcloth on your hair. Your fingers are more like a wand you can scrub with and the water carries it away.
they live
Water flushes the dirt away. You admit to leaving it behind.
SteamwayPro
George
A CRB is your Fingers
I CRB every Residential carpet
they live
I CRB every carpet
Dry?
So if I crb then extract am I not removing more soil than padding?
What if I pad after crb and extraction?
Really its just another tool.
Wicking happens even if its 30 minutes. Ive seen plenty of wicking from padders because they didnt flush the spill. But I've seen it from my own work too. Thats where experience matters I suppose.
Thats why I thoroughly soak spots with prespray to neutralize then flush. But I dont have to lug in a portable to do it. Same with furniture.
Since I got the WM and now butler I haven't padded a carpet. I just find it unnecessary now. But there are accounts I dont do anymore where access was an issue.
Ive padded a lot of carpet. Worked for CD for awhile and did a lot early on in my business. I still have everything to do it with. I just like what im doing now.
I'd rather wash my carpet than wipe it.
2-5hr dry time for wiping? That's the same as washing. If that's the case, then I'm leaving behind the same amount of water as you are. And I'm probably going faster than you are to meet the end goal.
Just admit, you were too broke to buy a good truckmount, so you went the buffing route.
I put some of the blame of this scam cleaning process on the truckmount manufacturers. They have made some junk machines to really pop the industry's bubble of really doing a good job and having a reliable machine. When one of these lemon truckmounts crap on a little guy who has no backup units to depend on, it can ruin his little business he's trying to start. So it's easier to just put $5k on a floor buffer and chemicals with a couple vacuums and survive
  • Dislike
SteamwayPro
George
Yes I admit VLM leaves behind but what's left behind crystallizes
What happens to the 2-5 hour dry time (on a good day) dirty water left behind using HWE
Water flushes away most ( 50% - 75% ? ) of the dirt but not 100% of the dirt
If the carpet is wet after you wand that's all dirty water with prespray detergent dirt in it
What happens to what's left behind after you wand
VLM crystallizes what happens with HWE
If it takes 3 hours to dry that's 3 hours of dirty water left behind
If it takes 5 hours to dry that's 5 hours of dirty water left behind
You see the dirty water coming out of your TM when you dump. That's also what your leaving behind
What happens to all that dirt prespray detergent left behind in the carpet after HWE
VLM crystallizes what happens with HWE ???
they live
Where do you get your numbers from?
HWE when done properly flushes away the dirt and detergents. Thats the whole point. We flush away what you leave behind. A little longer dry time doesnt make a difference other than it takes a little longer to dry.
Padding makes the carpet look clean. HWE gets it clean.
encapman
Rick Gelinas
Interesting discussion going on here. I'll start by saying that HWE is still the most efficient way to flush the highest level of contaminants from the carpet in a single shot. And that can be helpful in the case of a pigged out neglected carpet. However, to think that HWE alone can remove everything from the carpet is not realistic.
When we apply pre-spray we're adding a strong detergent, because we need the firepower to break up and emulsify soil. Now we have 2 components to rinse (1) pre-spray and (2) carpet grunge. We'll call that combination the "HWE target load".
So can HWE work to eliminate all of the "HWE target load"? No, it simply can't.
To illustrate: Consider taking 1 gallon of red paint / representing the "HWE target load". Now let's dilute the gallon of bright red paint 5 to 1 with 5 gallons of hot water. What do you have? It's still bright red! Dilute it with 10 more gallons of water. Still bright red. Add 25 more gallons of water. What do you have? Still red. It would take hundreds of gallons of water to get the water to a level that you can't see a trace of red.
That illustration describes the HWE process. The "HWE target load" is reduced (somewhat). But through the process of dilution and extraction, there will always be some remnant of the "HWE target load" left in the carpet. Anyone can easily recognize this fact. Even when an extremely effective HWE cleaning is performed, there would still be some "HWE target load" (i.e. red paint) left behind.
With encapsulation the soil can continue to be recovered after the initial cleaning / providing that you have an encap product that dries to a brittle crystal polymer that can be extracted through routine post vacuuming.
To be 100% honest, no cleaning method is completely perfect. So to say that any method achieves 100% soil removal is ridiculous. Our place as cleaning professionals is to reduce the "HWE target load" to the highest level that's reasonably acceptable. To imply that a method delivers total sanitizing, when we're dealing with carpet fiber, is simply not realistic.
This video about encapsulation pre-spray explains how adding an encapsulation component to our pre-spray can further reduce the "HWE target load".
they live
It's interesting how the argument is between one service only providers.
If you do both, you don't have to justify what you're doing, just do what's right.
Ive done both and I agree neither is 100 percent.
But the paint comparison is more like padding than extraction.
Would you wipe your coffee cup with a dirty rag and not rinse it with clean water?
Extraction removes allergens padding dilutes them.
Im not against padding. Its just more labor takes longer and is not as healthy for the end user. You are leaving most everything behind plus the chemicals you are adding to the carpet.
Vacuuming from client will not remove most of it. If it did it wouldnt be there in the first place.
Spots are now spread around in an altered state but not removed from the environment.
  • Eyeroll
SteamwayPro
George
YUP neither Method is perfect and both Methods have plusses and minuses
After 25 Years of HWE and now 6 Years of VLM
I prefer VLM with NO residue HUGE Profits and 1-2 Hour Residential Dry Times
Why do people let their grandchildren spill Red Drinks on beautiful carpet
they live
Because they know the steam cleaner can get it out.
Are you sure about that? Depending on how long it's been there, neither method probably won't budge it. 😬 Especially that much😉
