- Jan 5, 2007
- Name
- Kevin Leach
Man, you guys should have parked at the front door.
Waldo said:Your brilliant Bob. People discovered this 10 years a go on ICS. Oh BTW. "In fact it wasn't even vacuumed or pre-scrubbed". I have always thought Kenadians were sub par cleaners. Well this proves it. Tell Werner he can kiss the Top 25 ranking good bye.
Golden Boy
No Worries. Not like I asked to be on it.Waldo said:Your brilliant Bob. People discovered this 10 years a go on ICS. Oh BTW. "In fact it wasn't even vacuumed or pre-scrubbed". I have always thought Kenadians were sub par cleaners. Well this proves it. Tell Werner he can kiss the Top 25 ranking good bye.
Golden Boy
sweendogg said:I only did the 03's
going up did in fact increase the temperature at the floor from 02's to 03's. .
danielc said:When I was at Mikefest I demoed several so called high flow wands and could instantly tell they would not clean any faster or better than my 6 flow wand. You still have to pull the wand the same speed. One of the wands was a 12 flow TI wand hooked up to an Aerotech running at 250 and I had to put the same amount of effort and time to clean the scrap carpet as it would have taken with my 6 flow wand. I totally get the theory, but when I squeeze the wand valve and the solution feels the same I don't see any need in getting all excited over better cleaning. I watched Bob in the video and he was moving slow and a lesser flow wand would have given the same results in the same time.
sweendogg said:Meat meat Meat.. keep up man.. did you miss all the text where until today I had 02's on my greenhorn.. so I took measurements at a few different pressures first with the 02's... Then I installed the 03's and took different measurements. It was consistantly higher temp.. (granted by only 5 degrees) but I cleaned our showroom and different see any difference in dry times. I have a few places comeing up that should tell me if it makes a difference in cleaning ability. I'd be interestd in seeing these types of numbers from some one with a higher heat machine... I'd also like to see real at the floor temperatures from different machines at different flows. Across a 100 foot run on a 65 degree day, combined with about an 1.2 inch air gap from jet to carpet. My machine takes a 40 degree loss. Like I said above, I have a bit of high heat envy.
edit: sorry that was a confusing post. i was kinda of explaining why I only went up to 03's instead of 04's. I did in fact test 02's and 03's. I also tested the difference in manifolds from the greenhorn to the prochem quad jet with jet extenders and 03's as well just to see a reference.
