- Apr 14, 2011
- Name
- Giorgio
10. You get a blister on your little finger.
9. You vacuum before steam cleaning because your a Premium hack
8. You actually "shake" your Hydroforce sprayer before using it.
7. You clean out your lint basket once a year whether it needs it or not.
6. You pre scrub with a Grandi Groomer
5. You don't use Green Glides because 10 extra dry passes works almost as well.
4. You insist on running 5 to the door on every job.
3. You setup living quarters in the back of your AT Vortex because you can't afford rent and a truck payments at the same time.
2. You place airmovers in every room before proceeding to the next.
1. You still use a porty and 175
