- Nov 25, 2006
- Name
- Ron Werner
the soln used when clawing is not just water. I apply a product to deodourize, sanitize, and dissolve the urine salts, in the same way John describes. Then I can extract the source. If you remove the source, its not going to smell.
I've tried the fire and forget treatments, never found one that really did the job. Then again, Pee Eradicator was never offered by my supplier.
Best of both worlds, mix up PeeErad, then water claw it.
If John applies of PeeErad to a urine spot in "equal amounts" as the urine, won't it soak through to the backing and the floor, considering it has to go where the urine went? He leaves no dehum or airmover, just explains it will remain as wet as the original urine spot. With a water claw we can remove over half (conservatively) of the liquid, allowing it to dry faster.
Andy, I only vacuum as much as I need to. Average house takes 45 min, not 2 hours.
At least if a VLMer doesn't vacuum they haven't created mud in the backing, it just stays there.
Now I bonnet in between steaming seems to be a good compliment to use in the interim between steaming. I wouldn't use it on any residential though. :mrgreen:
