Best portables these days...?
Yes I have the same one with heat works great BUT wont go up stairs even when I was younger. I talked to them and said to extent the handles higher.The unit I have has 2 3stage vacs and 500 psi. But nothing is perfect .
I have an old EDIC Aquafresh which I use for the odd time I might have to go upstairs. Got it brand new in the box a couple of years ago from a guy who was retiring. Brand new 25 year old machine. Only 100 psi and 2-2 stage vac motors but the beauty of those machines is the folding handle that lets you go up stairs easily. I routed the power cord out the side as it was catching where it was originally mounted. My main portable is an old Mytee speedster with a 500 psi pump and 2-3 stage vac motors. Goes up stairs somewhat but could use taller handles as well.
icleancarpetz
Rafael Samson
You have an Ole Mytee?
Man i wish i kept mine. Best portable ever. Back then it was called Mytee Stinger. Yellow Bumblebee, 2-3stage and if not mistaken i think 150 or 20o0psi. Perfect light weight. Easy handling. Wish i could find one.
Bro, that's basically a Mytee Speedster.. Any speedster without heat should fit the bill..
I can lift it into my van on my own still. I replaced the pump with a Pumptec 217 permanent magnet DC motor. Comes with a rectifier, plug and play. Draws under 3 amps.
Truckport???
who came up with that lame name?
They used to have one called the Truck Force. Heavy and the waste tank was much smaller than the solution tank. Came with an automatic fill and empty. I used it for a couple of years then sold it.
Truckport is a Sandia Sniper portable..
Truck Force was MasterBlend's heavy ass portable..
