Big Boss
starrett
Anyone out there using Mytee's Big Boss sprayer. Thinking of replacing my multi-sprayer with one. Can you change tanks easily to change product? Different tank for pre-spray, scotchgard, deoderizer or would this be cost prohibitive? Sprayer too big? Pain in the ass? Just perfect? Thanks in advance, Daryl
John LaBarbera
Tanks can be changed easily and the pump and solution line purged in seconds. Some think it too big, which I don't get. It has a 5 gallon tank that is graduated and so you can put only what is needed instead of filling if the weight is a problem. If you have a big job at least you have the capacity.
I have one and like it. It IS a bit big, and if I was working out of a standard size van I might find it to big to deal with. However, working out of a Vortex gives me plenty of room to store it. Tanks change out very easily. Battery lasts forever on a charge. The suction hose that comes out of the top size of the tank needs a gasket on it where it exits the tank. Lifting it into the Vortex makes you have to tilt if back and the solution in the tank pours out of the back when you do that. Other than that, it's a fine working machine.
John LaBarbera
Leslie Judson Jones said:
5]http://www.youtube.com/watch?v=9oGBvPtkX545]
Thanks Les, but that was not the Big Boss we were talking about.
