Comparing my new Titan to My Vortex
Kevin McCreary
I put my new Hydramaster Titan in service last Wednesday. I didnt expect it to
replace my Vortex. I was pleasantly surprised when I fired it up. While it is defiantly not
a Vortex I thought the heat was better. It held a steady 230 ATM with two .012 wands wide open for
as long as I wanted (keep in mind my vortex has the pre-heated fresh water tank which you are constantly dumpimg cold water into with the
flow rates I use). It seems to have enough power to run 2 wands with out any real noticeable loss of
vacuum or pressure. The vacuum is pretty darn good (much quieter) with 2 wands 150 ft of 2 inch each, but you notice the difference
when you add much more than that. I think the vortex is set to about 17 or 18 inches of mercury and the
Titan is only 14 or 15.
Im not sure if I dare adjust it to more. I put it in an 08 1 ton Chevy extended which rides like a Cadillac and I can get serviced with ease.
The lack of space is the killer, I still have to figure out where stuff is going to go. Even with my Vortex I dont ever climb into it so its no
different there, but there is absolutely no extra room. Oh and I can only carry 120 gallons of fresh water. However the thing will
save me over 200 per week in fuel which will pay for itself quickly. The Vortex is still the Best machine I have ever seen or used, but
big slide ins still get the job done quite effectively. The jury is still out to see how many hours of trouble free operation I can get from it.
W
White-Magic rebuilder
Very nice Kevin. May I ask about what the Titan cost? I'm looking to get a new machine soon.
Rob Allen.
Art Kelley
Jay DeLaughter said:
can't you use vege oil with a Vortex/diesel or is that getting too hard to come by?
Some of the Vortex users are mixing tears with their diesel.
Kevin McCreary
Mikey, It costs me $120-$130 per day to fill my vortex up do 5-7 jobs and drive 50-100 miles. I just got home did 7 stops drove 76 miles filled up
this morning for $109 and burned just over a quarter tank. You do the math. My Vortex was a huge m.p.g. hog! It sux on the highway it would
red line at 3000 RPMS and only go 68mph. I might save two trips to the gas station every week. Also the time possibly saved with a Vortex
I can make up for by being able to drive the legally posted speed limit. I cover a very large area. I think you might be
pissed because your stuck with a big under powered diesel POS. I will put it to you like this I'm having NO VORTEX WITHDRAWALS!
Its a good thing the guys at Blueline where smart enough to put the Vortex in a better truck.
I fill up 2 times a week
I dual wand most jobs.
Most days I drive under 20 miles to do 4 or 5 jobs.
Fuel is under 5% of my daily gross.
I carry every thing and more.
The UD has had WAY fewer problems then my GMC/PTO ever did.
No regrets what so ever.
John Watson
Becker, He sees them all the time. The flippen ones and the flying ones which circle him constantly :mrgreen:
Kevin McCreary
Yeah, I sold the Vortex to a Rainbow Franchise.
Mikey, your 100% correct about a P.T.O. in a Chevy/GMC van
if you run them consistently 30 hrs a week they break a lot. Thats
why I opted for a slide in.
It does suck I'm limited in space, but it really saves me gas $$,
like Mikey said its still less than 5% of my gross, but It just makes
sense to me to quietly put as much $$ in my pocket as I can.
MicahR
Micah Richardson
I have a few pics of a Titan we received as a Beta for a local customer.
Impressive machine!
Now That's a Blower!
Yup that's a 2 1/2" hose port
Water Box big enough for a midget to hide in.
Was surprised to see a non Hydramaster style of chem pump.
Pulsation dampner?
Goofy 3 vac port design, if it had a GG dual port set up, you could put 2" Inside and 2.5" outside, making it more streamlined and not having to use any plastic fittings (better airflow).
That looks like one cool machine. I see a ton of heat exchange tubing in a few of those pics. What kind of port does it have to hook up to vac and exhaust. I'm guessing it has a blower exchanger.....just hope it's none restrictive. Sounds like it's one hot machine......looks like it may be on my list for replacement machines when I get my CDS paid for. Just hope it's not a fuel hog!
I was asking where is the pulsation dampener, if there is one.
The Exchanger tubing you see looks like the blower HX, typical radiator style.
Becker
Anything good to say Greenie?
It's a purty color, so shiny...
And CLEAN!
packfancjh
Chris Hagen
Steve, the Titan is better in a few ways. It has a 61 hp GM vortec motor, Tuthill 5009 blower, 5.5 gpm pump, 270 degrees of heat, etc. It's a really nice machine.
steve frasier
the boxxer and the titan have the same foot print, they come in different colors, the biggest difference is that everything on the titan is bigger, motor, blower, water box, etc
Glynn
The Titan DOES NOT have the same footprint as the Boxxer, it's much larger in fact. I have has both side by side and the difference is huge.
The Titan is a very powerful and quiet machine, in fact it's the quietest Iv'e ever heard. The heat is so great that the vac hoses is sucking in and closing when RXing. It sucks like a bitch even with 3 RX's at a few hundred feet each !.
Becker
I was going to say even in pictures it looks much bigger.
61 hp, bigger blower all built into the same footprint as the boxxer? Come on!
Don't get me wrong, I'm not downing the machine at all, just asking a few questions, I've never seen the machine in person.
Glynn
Just so you get an idea on its size, the exhaust you can put your hand right in it and reach the exchanger its that big.
DevilDog
Just learn to clean better and save yourselves a shit load of money. My God.
DevilDog
steve frasier
if it is not the same foot print then my bad, just repeating what a sales person told me
Kevin;
Congrats on the new TM.
It looks like HydraMaster has decided to change to General Pumps.
Good move on their part.
