Devastator Tile wand
Foster made the comment that it will draw interest, for users who do a ton of tile, they'll be drawn to it.
But for every tool Tom sells Mike will sell 9 brush glides because it's way more affordable.
Let me know if Foster is right.
Meter Maid
The Undetective
I can’t really tell, but it seems like my SS 12 with a Brush Glide will also edge better.
He'll never catch up..
You goobers are cheap af..
Reactions: Nomad74
It is a cool tool, one that I have offered to show off at two different events.
I only need two wands in my truck.
Dev 12 and SS12 and I'm completely covered for any situation.
When was Bob ever right?
Reactions: FB7777
I’ve used this new tile wand that Tom invented and its amazing. Its not the same one that was being tested out a couple of years ago in Florida. Tom made some improvements that no one else has done or thought of. Its awesome.
A true professional uses a dedicated tool for the job. Not a Swiss army knife setup. Who really wants to be sliding glides off and on between jobs anyway? Unless you keep a brush glide on your wand all the time and only use it on tile. Then and only then you are a true professional.
Meter Maid
The Undetective
It takes about 20 seconds to switch glides.
so with that logic you should be using a vacuum for open areas and a separate vacuum for edges and uph.
and a motorcycle for day trips that would never see side bags for over nighters.
or a pan for eggs and a pan for steak and a pan for pork chops and a pan for grilled cheese and a pan for award wining caned chili
Comical.
Reactions: FB7777 and BIG WOOD
Comical.
Your judgment is clouded.
Whatever works for you. When on a job I like having the tool ready to go. I don’t like having to change out heads on equipment or fittings on brass to make something work. Now if you are a part time cleaner like the Metermaid, then go for it. :)
And Mikey. You know in 10 years you’re going to make a completely different argument. I’ll be pushing glides and GVF and you’ll be into Corvettes and banjos.
Reactions: BIG WOOD and SamIam
Are u getting the tile wand????
You bet your sweet bippy
