diffusiophoresis
FB7777
Weekends deserve better threads than this.
Perhaps then you should come down from the balcony, hop on stage and show us all how it's done
Oh, I’m still around on weekends. I just stop posting informative, helpful posts that require cognitive effort. On the weekends, I relax and just post pissy posts.
sounds like more bullshit bafflegab to me. Next time you have a red wine stain on a carpet, try cleaning with pure, distilled, fresh or whatever water and see what happens.
steve_64
I've pulled plenty of wine spills with just soft water.
steve_64
if it was that easy, people wouldn't need to call us.
All a custys has to do is put a damp towel on a wine spill and weight it down and wait a day.
I recommend this often but most want to give me their money for some reason.
DAT
Bill Cheryl
Missing the point...
DAT
Bill Cheryl
One of Jim Pemberton post discussed that sometime just fresh water or distilled water can remove the wine spill without additional steps on the upholstery. Point of the article is the science behind the rinsing power of fresh water without any added chems to it. You do this after applying cleaner to said fibers.. less can be more for effective cleaning
Is said fibers the same as the fibers?
Am I smart for having said said fibers?
DAT
Bill Cheryl
Cotton, wool, synthetic..what ever it was mentioned in the article...
diffusion, osmosis, diffusiophoresis..
Nature does not tolerate a vacuum or imbalance indefinitely, or those with an imbalanced nature :biggrin:
Reactions: DAT and Nomad74
sassyotto
Paul
way back when, I tried going without an emulsifier and found that it cleaned just as well as with one. Surprised the heck out of me.
The plus side is that it seemed the carpet stayed clean longer too.
I liked it so much that I took the chem pump off my water pump. That was years ago.
At least now I know why it works!
Thanks for the post!
Reactions: dealtimeman and DAT
Ron-- if i understand the report correctly, it doesn't say to clean with plan water. It says to use the proper surfactant or chem but rinse with pure water without any added chems.
Reactions: DAT and SamIam
DAT
Bill Cheryl
Thats how i got it.
It may be true for specific stains but you have a better chance of removing soil using an extraction detergent when rinsing. Years ago, I moved from a company who always used an extraction detergent after the prespray, to a company who rinsed with fresh water only. It was a struggle to clean as efficiently with just the prespray. Many times, having to stop and respray certain areas.
