- Sep 4, 2012
- Name
- Jesse Lowe
Do you need to rinse a dye stain remover after you finish with the heat?
Are there any valid arguments to support NOT rinsing it?
Well... It continues to work after I'm gone!
I would say most reducers must be rinsed to stop the action. Unlike peroxide products, reducers are usually designed to work quickly. Not rinsing a reducing agent may result in color loss to the carpet. The only exception is mild reducing coffee/browning agents that are designed to be sprayed on and left. These are usually liquids such as chemspec liquid browning treatment.That's true, but at what risk?
It may very well continue to work not only after your gone, but even after the stain is gone, and what exactly is being left behind if anything when fully dried?
If I mist some 40V on an area or spot and leave it to work after I'm gone, I know that I am only leaving benign water behind in the end.
What is a reducer leaving behind after the liquid has evaporated?
I couldn't tell you.
Necessary data.
