Flow and pressure poll
Lets keep this simple.
In regards to average residential HWE carpet cleaning
What flow is your wand spraying at and at what pressure?
using a prochem quad Jet. : 12 flow 600 psi. Using a greehorn: 10 flow at 600, but getting ready to go up to 15 flow.
daniel@procarpet
I guess I need to up the flow on one of my wands. I run standard 6 flow at 450. I know I am wasting heat. I think I will up the flow to a 12, 6, and 8 flow. The reason I am concerned about uping the flow is using too much water. Right now turning the water on is not really an option on some of the rentals I clean. Yesterday I cleaned a house that I used a pump sprayer for most of the job and hf for two rooms, keyed the wand on the back stroke only, and did everything I could to conserve the 75 or so gallons I had on board. I was working my down the steps which was the last thing I had to clean and ran out of water with four steps left. I had to knock on the neighbors door to get permission to hook up to their water supply. This rarely happens but would happen a lot more if I doubled my flow rate.
joeynbgky
Joey
450-500 psi. whats a flow? lol new bentley stock wand so whats the flow
Loren Egland
Loren Egland
Are we comparing apples to oranges?
I am at 450-500 psi with 5 number 2 jets. BUT, I am running 3/8" solution hose so I maintain more pressure and flow than 1/4". My Powermatic has a pressure regulator instead of an unloader valve, so I don't drop 200 psi when I pull the trigger. Only about 25-50 psi difference. Bottom line, more pressure and flow at the same machine settings.
At least that is my understanding, so correct me if I am wrong.
CleanEvolve said:
Whatever flow my TM came with?? and 350-450 psi.
Flow= Your jet size. Like 11002, 9502 the last 2 numbers tell you what size jet it is.
I'm running 12 flow @ 400-500psi with 1/4" solution hose. My gauge drops about 100psi when keyed.
