How many hours a year do you put on your truckmount?
billyeadon
Bill Yeadon
During our Strategies class Chuck Violand does a cost analysis to figure pricing. In his model he uses 800 hours.
FOJL
I've been consciously trying to lower machine run time. Still close to 700 this year.
Doug Cox
Doug Cox
I use to do about 1800 with my CDS. Since the new slide in , I have been at around 1200- 1300.
joe harper
joe harper
Everest 650 hp.............1121 hrs
Prochem 405................836 hrs
Prochem 805................37 "17 days"
Butler..........................sold last year...."miss the old girl"...5500 hrs..
Zee
I think it depends on what truckmount you using- heat ex or propane/diesel burner.
I do make an effort to keep my hours down, by not running the truckmount while vacuuming, setting up hoses, prescrubbing etc..
I know with heat ex models one would be running it more to heat up(right jimmy olas?) He pulles up to a house and the first thing he does he turns on the machine.
I only run my diesel burner truckmount when its being used for cleaning or filling up sprayers.
The other thing I noticed, it gives an impression to my custys that I was quick, by not having to listen to that "loud big machine" out there for too long.
The way I see it I can save sometimes 25-30 minutes on my machine hours on 1 job. It adds up quickly to a couple hundred hours.
With this I used my truckmount for almost exactly 500 hrs since the 1st of january.
My thoughts..
Excellent post Zee.
I was wonderin' if this example would come up, where FREE heat isn't really FREE.
kmdineen
Kevin Dineen
About 700 hours for me. I pre vacuum, move furniture and pre spray with the Butler off. I only run the truck to rinse.
Zee
Yup Jeff there is no free heat with heatex models...
The extra gas and the wear and tear of the machine by running a lot of hours, will somewhere cost at least as much as my diesel for every 20-25 hours.
I run about 22 hours burning 5gallons of diesel. The heat is awesome and keeps up with my 20flow.
joe harper
joe harper
Gentlemen...
You CAN'T sell me on fuel fired HEAT....
My 1st TM was a 1150 Poweratic...StinKinG KERO... :roll:
Yes the heat was great...BUT...SMELL was unbearable... :!:
Remember ..I am in fla..It is 110 degrees in the trucks ..to start with... :wink:
We run BIG TM'S...Heat is never an issue..AT any flow..!
If we operated in COLD weather... :?: ...I would certainly use fuel fired heat..Seems rational...
NO propane either... :!: don't like riding around with a BoMb... :p
Loren Egland
Loren Egland
That's why I run an electric truck mount. I don't want no stinking engine exhaust or a gasoline bomb in my truck. :p
Besides, cleaning performance is the same on all machines, right? :wink:
W
woodsey
Interesting point on fuel fired heat. After going to propane I did nottice I put less time on the machine. As a guess I run about 30 min less a day. Five days a week X 30 min = 150 min or 2 and 1/2 hours a week. If machine depreciation is $8 hour X 2.5 = $20 a week or $1040 a year IF you work 52 weeks. Another way to look at it is 2.5 hrs a week X 52 = 130 hrs a year. If you put 1000 hrs on a machine a year and reduce run time by 130 hrs that is a 13% reduction in wear and tear. I know there are some variables in this but I dont think the "figgers" are to far off. Would like to hear other opinions. Woodsey
Zee
Mr. Harper I don't really have a smell issue with my truckmount.. I keep hearing about how bad everything smells with a fuel fired one but honestly i don't have an issue with it. i do keep open all my doors and windows when I'm working with it. Except when its raining..which is a few days out of 365 in a year here in SoCal.
I calculated about $280.00 to $300.00 a year on diesel if my machine is running for 500 hours.
In my opinion that's not too much if I save a couple of hundred hours runtime.......
I burn propane for engine and heat
no smell.
Its no more a bomb than a gas tank. in a year and half never had any blow up issues I've heard others whine about. They must have done something really weird to get a response from a LG like that.
run about 500 or so hours/year
I use a HF so the truck starts after I've finished vacuuming.
