Hydroforce question???
Nate The Great
Ok, I used to use the HF before. I've switched to a battery sprayer since. I'm thinking of going back to a HF. The question is, How can you tell the difference between high pressure and low pressure HF's? I have like 5 or 6 and I know for a fact 1 is a low pressure one. Is there a way to tell?
Erik
Erik
The spay gun, I think the dema valve has a pressure rating on it.
CleanEvo
Why are you switching from a battery sprayer? I am thinking of switching to a battery sprayer, i've been having some issues with the HF sucking too much chems.
Nate The Great
Some of it's laziness, sometimes I just want to hose down the whole job. When you run out and gotta stop to respray, it eats some time. As long as I don't crank up the little giant heater before using it, I think I should be fine. :lol:
Motomark
Hydraforce is great for Large Jobs and you will use less Chems when mixed right
Do you have the one that adjust for ratio ? :eek:
Nate The Great
I think I got 1 or 2 of the HF revolutions (adjustable ones) that I got with some used equipment. I've heard they suck, not in a good way either. Ivebeensold
Brian R
Brian Robison
Hydro Force is a great concept. It just needs some tweaks.
It's just really simple and inexspensive compared to some of the batterry sprayers.
I did like that one battery sprayer...what the hell was it called? It was under $100.00.
KP had one and it worked really well.
Someone knows what I am talking about. To early to think.
Nate The Great
Hudson sprayer??
I've got the 2 electric sprayers Larry Cap. loves, 2 spraymate sprayers, and the omni battery sprayer I currently use. It just sucks to run out of 2.5gallons and needing to stop to refill.
Low pressure was usually a Kingston valve at the handle. The HP had a hose with the gun attached.
GeneMiller
gene miller
there is a notation right on the valve of the adjustsble one is has lp or hp
gene
Years ago I had a little blue cup with a bunch of different colored tips in it for the hydroforce. Each tip metered at a different ratio. It also had a chart with it that told you which tip to use in what situation. I kept it so I wouldn't lose it when I switched to a multisprayer.
Now I can't find it!
Do they still have those available?
Zee
I have a high pressure HF. I know for a fact it draws more chemical then it should- with that said: I don't care if it sprays a bit more!
Our chemical expenses are some of the smaller expenses we deal with in this business. A little more chem hitting the carpet just makes me clean better...
Brian R
Brian Robison
Nate The Great said:
[quote="Brian R":j5sfhuqk]Hydro Force is a great concept. It just needs some tweaks.
Hudson sprayer??
I've got the 2 electric sprayers Larry Cap. loves, 2 spraymate sprayers, and the omni battery sprayer I currently use. It just sucks to run out of 2.5gallons and needing to stop to refill.[/quote:j5sfhuqk]
That's the one
Yes, Marty. Give me your mailing address and I will put one in an envelope for you. Of course, I fI don't do it today, you will either need to come down to Connections tog et it or wait until I get back.
Curtis Pennington
Marty if you cant use one tip for everything your dumber than I thought..... its not freakin rocket science.
Hydroforce is by far the easiest way to clean with a TM.
MicahR
Micah Richardson
I was told by someone @ Hydroforce that there is no difference between the high and low HF's besides the wands attached.
Maybe Scott can confirm that for me.
If you haven't figured out by now how dumb I am, then who's dumber?
Nate The Great
Hmm, that makes me wonder.... I thought I read some where that if you use a HP HF on a LP machine, it'd draw too much chemical because of the flow? 1 of my LP HF has the handle/wand on it. I just wanted to make sure someone didn't put a HP hose and gun on a LP HF. So, hopefully, ScottW can answer this question.
Curtis Pennington
Do you think I never knew?....who's dumber now?
Lonny
FWIW, I tested the draw on my adjustable HF today, it was spot on at 4:1, Go figure. I started using a pump up, cause the HF started clogging after using powder pre-sprays and not rinsing it after. I just need to remember to rinse each and every time.
Measured with 500psi, 160 degree water.
Eric Valentine
Eric Valentine
[quote="Brian R":21f8m0iw]Hydro Force is a great concept. It just needs some tweaks.
Hudson sprayer??
I've got the 2 electric sprayers Larry Cap. loves, 2 spraymate sprayers, and the omni battery sprayer I currently use. It just sucks to run out of 2.5gallons and needing to stop to refill.[/quote:21f8m0iw]
You should get a Mytee Big B.O.S.S. sprayer. rechargeable, sprays at least 40 gallons on a charge, built-in charger that uses a computer style power cord, 15 foot coiled hose, you can change the jug very easily, and it holds FIVE gallons (enough to do a decent sized house)
Nate The Great
Eric Valentine said:
[quote="Nate The Great":1b08ntqc][quote="Brian R":1b08ntqc]Hydro Force is a great concept. It just needs some tweaks.
Hudson sprayer??
I've got the 2 electric sprayers Larry Cap. loves, 2 spraymate sprayers, and the omni battery sprayer I currently use. It just sucks to run out of 2.5gallons and needing to stop to refill.[/quote:1b08ntqc]
You should get a Mytee Big B.O.S.S. sprayer. rechargeable, sprays at least 40 gallons on a charge, built-in charger that uses a computer style power cord, 15 foot coiled hose, you can change the jug very easily, and it holds FIVE gallons (enough to do a decent sized house)[/quote:1b08ntqc]
Eric my friend, you've seen how skinny I am. I'm not going to carry/roll around 5gallons or I'd just put a pump on a 5gallon bucket. I'm lazy and weak. You seen my guns, only a .22 lmao.
Ya the one that explodes when using high pressure thats the the low pressure one. the others wont pop just kidding good luck.
That is essentially correct. As far as parts, the wand is the difference.
Each unit is calibrated for the right flow. The low pressure models are calibrated at 100 PSI while the high pressure unit is calibrated at 250 PSI.
floorguy
Doug
track down an old porty and convert it to a sprayer only....
thats what i did, and use a 50' hose...it can almost reach everywhere in a house....then its also 10-15 gallons...
Nate The Great
Douglas, you crack me up... please re-read my comment to Eric... :lol: Now for commerical work, the porty sprayer works excellent as long as its a on-demand pump.
floorguy
Doug
yeah but you see the porty rolls quiet easy'
Scott,
1) What happens with the dilution ratio at 500-600 psi?
2) How does the temperature affects the dilution ratio? And at what range of tempratures?
