- Oct 22, 2012
- Name
- Ron Marriott
YOU NEED A BIGGER SHOP....This host liberator vac was $250. CRB with a vacuum. I'm sure I can find a use for it.
That's for sure. Maybe some employees too so they can play with them.YOU NEED A BIGGER SHOP....
I'm thinking of using it as an encap machine. Can use it to vacuum the carpets first, spray the encap solution, brush it in, then vacuum up any debris that the regular crb's spit out. Either that or use it as a coat rack.Such an awkward POS to use
The way I want to use it, the vacuum is important. I'll see how it works. Not looking to use host product.I've got one. Justin bought several at auction and stripped down to crb only.
I clean carpets for a hobby.You need a hobby other than TV.
Come onnnn dowwwn.... for free labor, I’ll hobby the hell out of you.I clean carpets for a hobby.
That gun is as worthless as that CRB
I thought they were 17+1 longer magazine?
it might be?
I could be wrong, but thought I've stuffed 18 in the mag
nevertheless, don't let Mike influence you .
try as he may, he'll never be a redneck
it might be?
Either will you MulletMan...
Both you guys, get the Fook off my thread. Start your own guns and ammo thread.I'm a "country boy", Mike
not a reformulated Cali-nut
I'm hungry
Just about as heavy. The caddy works well though. Easy to go up and down stairs.How heavy is your host
Almost looks like a post office box on the street
I'm hungry
It's actually very easy to use. Trying it out in the shop today and it's very agile. The handle folds in both directions and it spins on a dime. You can dance with it. Seems to be very powerful as a pile lifter, not sure how good the vacuum is. Looking for a building to try it on.Seems awkward like using a dehu to scrub
