Interview With Dana Kothrade 10-15-08
DANA KOTHRADE
David Gelinas said:
Could you please explain a little more about the stone “wax” mentioned in the pre-questions? When you mentioned paste you got me thinking of very old school SCJ traffic paste wax for wood.
I’m assuming there are no similarities correct?
What about discoloration?
Can soil/dirt be embedded into the wax?
Does it discolor over time?
Is there ever or could there ever be a reason to “strip” this product off of the floor?
What’s the possibility of “waxing” stuff to the floor when recoating, i.e. hair, grit, etc?
Is there a need to recoat and if so how often?
Is it UV stable?
When buffed, will it swirl like UHS finishes of old like Equinox or Signature?
Does it provide any hydro or oil phobic protection?
Wow! Thats alot of questions in one post.
Its not a regular paste wax, its the same product that thousands of fabricators use for edges to bring gloss and color by filling in the pores.
It hardens
It doesn't discolor
If buffed off properly there is no evidence its even there except for the increased repelency.
It repels water and oil.
Its only meant for use on counter tops.
XTREME1
RIP
Greg Crowley
I am a newbie to stone. I do a ton of tile and grout and have had a ton of my customers ask me about marble showers and foyers. I haven't taken the stone class is this an easy area for the monkey pads. we are talking about family use , usually just soap scum
DANA KOTHRADE
Mikey P said:
I have a Limestone job coming up in a very ritzy home.
Each 12 by12 tile has a very deep beveled edge, almost a half inch drop.
Some acid etching but mostly soiled.
How would you go about cleaning and dealing with the edge issue?
1. Sweep the area very well
2. Apply our stone cleaner mixed with hot water
3. 30 minute dwell time if extremely soiled
4. Rinse with low pressure ( barely enough to make your spinner turn
What happens next depends on the desired look...
Honed dull? 200 grit monkey pad
Satin Hone? 800
Polished? Go up to 11,000
DANA KOTHRADE
Yes, go to www.monkeypads.com
We have a free training video there
DANA KOTHRADE said:
[quote="Mikey P":14x11dl0]I have a Limestone job coming up in a very ritzy home.
Satin Hone? 800
Polished? Go up to 11,000[/quote:14x11dl0]
How do I polish the beveled edge though?
No way will the MPs get in there.
David Gelinas
Dana, what do you see a job like you just outlined being billed at per sq ft?
Satin Hone? 800
David Gelinas said:
Mike is the beveled edge distorted? Most of the time the abrasion wont get into a pillowed edge
No, it's very smooth.
Too perfect actually.
DANA KOTHRADE
Mikey P said:
Can you give me a quick run down as to what will be taught in your five day class?
Its more like a franchise with no royalties than a class...
Here is a very short abreviated over view:
MAN MADE TILE
CLEANING
SEALING
COLOR SEALING
GROUT REPAIR
TILE REPLACEMENT
NATURAL STONE
CLEANING
SEALING
COLOR ENHANCING
COATING REMOVAL
APPLYING COATINGS AND SURFACE TREATMENTS
LIPPAGE REMOVAL
HONING
POLISHING
ETCH AND SCRATCH REMOVAL
MINOR REPAIRS
ADVANCED SLAB REPAIRS (TAKING A GRANITE SLAB IN TOW PIECES AND PUTTING IT BACK TOGETHER STRONGER THAN NEW AND VIRTUALLY INVISIBLE
COUNTER TOP RESTORATION
COUNTER TOP PROTECTION
MARKETING TEMPLATES
OFFICE FORMS AND DOCUMENTS
PHONE SCRIPTS
INSPECTION FORMS
SALES FORMS
PRICE LISTS
12 MONTHS TECHNICAL SUPPORT
HOW TO EFFECTIVELY SELL A HIGH QUALITY SERVICE AT TOP DOLLAR
THE PSCYCHOLOGY BEHIND SELLING RESTORATION TO HIGH END CUSTOMERS VS. CONTRACTORS
HOW TO PERFORM A PROPER INSPECTION
COVERING YOUR BASES AND YOUR BUTT
RISK MITIGATION
STONE IDENTIFICATION
AND ON AND ON AND ON
ITS A LOOOOOOOOONG 4 DAYS!
REST UP AND DRINK TONS OF RED BULL!
THERES MORE BUT THAT WOULD ALL TAKE AN HOUR TO TYPE IT ALL
XTREME1
RIP
Greg Crowley
just watched the video thanks. make a list of needed materials to do most in home projects and post them. so we know what to buy
east coast always gets screwed. I keep telling my wife it would pay off going to these schools. You would think she would be happy getting rid of me. I know Mikeysboard would
DANA KOTHRADE
David Gelinas said:
Do the MPs work on concrete as well as calcium based stone?
Yes but we have special pads coming soon for granite, concrete, corian and several other surfaces.
DANA KOTHRADE
Monkey Pads
Sqweegee
Wet Vac portable or truck mount
175 rotary machine, cimex or orbital ( I reccomend the "ORBITRON" or the cimex) WAY FASTER
Water
David Gelinas
That’s way cool, there aren’t a lot of intentionally pillowed floors out there now days (just poorly flattened ones). If the lower edge is still good than it wouldn’t seem you need to get down that low into the stone I wouldn’t think would you? It would seem that the only question would be if the MPS would match factory. Dana that would also go along with picture framing, how well do the MPs blend in with factory when it comes to picture framing?
What is your experience with Dry Treat Stain Proof sealer?
Have you tested it much?
Did I hear you say that you will have a comparable product soon?
DANA KOTHRADE
DANA KOTHRADE said:
[quote="Matt Murdock":3h15jpi1]just watched the video thanks. make a list of needed materials to do most in home projects and post them. so we know what to buy
Monkey Pads
Sqweegee
175 rotary machine, cimex or orbital ( I reccomend the "ORBOT" or the cimex) WAY FASTER
Water[/quote:3h15jpi1]
Bob Foster
Many of us clean tile and grout with a turbo hybrid.
What do you use?
Have you modified any of your tile and grout cleaning tools?
Do you have any better tools? Any good stuff you see in Europe that should be over here that might be better?
DANA KOTHRADE
Mikey P said:
[quote="DANA KOTHRADE":1yzpltau][quote="Mikey P":1yzpltau]I have a Limestone job coming up in a very ritzy home.
4. Scrub with tampico brush on rotary machine
5. Rinse with low pressure ( barely enough to make your spinner turn
Satin Hone? 800
Polished? Go up to 11,000[/quote:1yzpltau]
No way will the MPs get in there.[/quote:1yzpltau]
Dana;
Why do you not recommend any acid to use with the Monkey Pads ?
Wouldn't a harder stone require some acid,
to keep the polishing time reasonable ?
boazcan
Bryan C
How much additional weight would be necessary with a CR 48 Cimex or OP ?
Does the weight vary for each pad?
I have concrete counter tops. Some acid etching.
As per Dana's advice, I'm gonna go from 400 to 11,000 the seal then wax.
I tested the wax and it gave a real nice deep dark look.
DANA KOTHRADE
RickL said:
Earlier there was a comment about using an O.P. machine with the Monkey Pads and that it worked very well. Is this really the case? What machine was used and is extra weight needed and is it more effective than a 175 rotary?
The Cimex Three head planetary or "ORBOT" orbital machine will outperform any rotary by a huge margin. Less weight is better with these machines.
David Gelinas
Because of the flexible nature of the pads, do you find them cutting out the softer spots of the stone and leaving the harder spots; leaving the stone with a “texture” to it when it’s polished? I’ve had this problem with other similar pads.
DANA KOTHRADE
David Gelinas said:
I have used pads “similar” (fiber based pads with a ceramic based abrasive grit applied to one side) made by two different companies. Their grits have been “Course, Medium, Fine and Very Fine”. The other is done in colors but seem to most closely represent “1,500 and 3.000 grits”. The first ones worked well enough in most applications but had a tendency to cut out the softer spots of the stone and leave the harder ones making the stone much more “textured” than it should have been. Have you seen that with your pads?
If used improperly, that can happen. Using an orbital or cimex without weights virtually eliminates that. We have a next phase of the pads coming soon that are even more aggressive and eliminate that completely with any machine. We also have them for concrete, granite, porcelain and corian.
DANA KOTHRADE
Jim Nazarian said:
Can your wax be used outdoors on a concrete BBQ counter top?
Yes, just reapply more often, when repellacy dwindles. Varies, I applied it to my neighbors granite over a year ago and its in direct sunlight every day in San Diego and it still looks great and still repells
David Gelinas
Dana – “Hot Seat” is a great name for this I think. Not because people are raggen on you or giving you a hard time – it’s gotta be murder trying to keep up with all the Q’s coming at you. You’re doing a great job, thanks for your time.
