Mikey...are you ready to rumble??
Brian R
Brian Robison
I found these guys...they are in Walnut Creek...I am sure there are others.
Just thought I would post it.
Mikeyimitators.com
rhyde
rhyde
Owner Operator Scott Sunkel, a 25 year veteran, is known as an industry leader
well, this sounds promising :!:
daniel@procarpet
Mikeyimitators.com
Is Walnut Creek in CA? If it is then that would not be cool unless they had the name first.
Brian R
Brian Robison
It is...about 100 miles from Mikey maybe? I'll have to check the map.
Brian R
Brian Robison
Louis
Louis
The term "Steam" is a misnomer since the temperature to required to generate steam is never achieved (240° F) and would actually delaminate the carpet fibers from the backing. The recommended temperature is 180 ° to 190° F, and most truck mounted equipment manufactures are able to maintain this standard.
Last I checked steam is created at 212. I guess this industry leader has never seen a real Tm with serious heat.
daniel@procarpet
No water boils at 212. Water under pressure can achieve higher temps hence cooking with a pressure cooker. Without it you can't get the water hotter than 212 whether it is a rapid boil or slow simmer.
cu
im about 30miles down the road i aint heard of him...maybe he,s another legend in his own mind
