Ninja Warrior 1200 exhaust leaks water
JupiterCarpetgenie said:
Did the defoamer work or did you get a chance to try it? I am going through the same thing right now and would love a quick fix, especially on my tight budget! :)
~www.suncoastclean.com~
if there are no fittings leaking, (I'm assuming you checked, right???) if no fittings or pump leak, it has to be foam, dude .
foam gets sucked into the vac tube in the waste tank and dribbles out as water thru the exhaust
