Oil pressure switch leaking
Mr Brightside
Jay Wags
Hi guys I have a problem this thing is leaking pretty heavy and I just noticed it
It looks like it’s missing the cap in the center
I need to complete my day tomorrow but not sure how I’m gonna
The part number shows it’s a prochem part but is there anything I can grab at autozone to fix this and not wait
You can temporarily bypass the switch by removing it and plunging the hole with a 1/8 pipe plug if the machine won't start/stay running that means the switch is normally open and youll have to connect to two wires together. Keep in mind that you are bypassing a safty switch and it should be replaced asap but that should get ya back to work
Reactions: Mr Brightside
Yes, you can pick one up at the auto parts store. I bought a couple of them to keep on hand for a spare. Give me about an hour and I'll have a part number available for you to pick up
This is the updated version I have on my everest
Amazon product
View: https://www.amazon.com/Standard-Motor-Products-PS-135-Pressure/dp/B0011TY9VK/ref=asc_df_B0011TY9VK?mcid=184eb40bc4f53ffba68befef81a89e72&hvocijid=16017042778012889439-B0011TY9VK-&hvexpln=73&tag=hyprod-20&linkCode=df0&hvadid=730434204848&hvpos=&hvnetw=g&hvrand=16017042778012889439&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9057435&hvtargid=pla-2281435178338&psc=1
And the version you have pictured is the old version. the part number on it is 78826 7psi 2030 mex1
The plastic headed one you have crapped the same way on mine as well because the plastic weakened due to the heat over time
Mr Brightside
Jay Wags
Thanks for all the help I got the new part and it looks totally different
I’m trying to figure out best way to remove the old one
No way to grab it except in the back and it’s hard to access all of it
If you can't get a wrench in a 1/2" crowsfoot or a plumber's wrench should work
20250310_140234.jpg 20250310_140244.jpg Screenshot_20250310_135910_Amazon Shopping.jpg
Yeah, I remember tearing my old one up trying to remove it.
Mr Brightside
Jay Wags
Ya I got it out and now trying to get the new one to thread my local store said that nothing fits the threads correctly and not to do it wrong or ill ruin the whole engine
I doubt you will. The threads on the oil switch will get messed up before the block does. It's a weaker metal on the switch
I have no idea what you have or what you're doing at this point all oil pressure switch I've seen are national pipe thread (npt) 1/8 or 1/4 most all being 1/8
1/8 pitch is 27 tpi 1/4 is 18 do you have a pitch guage? If you do measure the pitch of the old then the new if i have that information i can you what to do to properly install
Maybe I got the wrong one now it’s bogging down when it’s under vacuum load
Oil pressure switch shouldn't have anything to do with the vacuum bogging the motor down . The oil pressure switch is eighter for a guage or more likely it's to shut the engine down if the pressure gets too low ie low oil levels or pump problems if that's the case it should shut the engine down completely if pressure drops below set threshold, not bog it down
I don’t know how but I’ll look it up
I’m gonna try to figure out how to change the coil packs
The little rubber cap on top of the vac gauge. Lift it up to release pressure.
Then put the machine back on full load. If it’s rediculously high…that’s why it’s killing the engine. Ask me how I found out about that simple fix. I bought a $6k blower and it was just the gauge😞
Reactions: Nate The Great
I turned a rx20 star the wrong way.. Never used one before, was sitting in the corner of the shop.. Beat the shit out of it then had to buy Jim Martin's old star off him.. Wasn't 6k unfortunately..
I also went to change the van's oil after seeing the oil light come on going up a hill.. Thought, let me warm up the oil first.. Turned van on, gassed it 3 times and it shut off by itself.. Locked up that engine.. :lol: Was a van I got for free, so the only headache was uninstalling the TM and stuff.. :shifty:
I love your spark plug story! Classic..:lol:
  • Wow
Mr Brightside
Jay Wags
Ok I got it running pretty good today I think…
The belts were the reason it was slipping and I’m having everything done
Mr Brightside
Jay Wags
Ok so the oil pressure switch and belts went bad at the same time and I’m also an idiot lol
But I’m good now
Latest Auctions
