One of our trucks
Hoody
Steven Hoodlebrink
Location
Bowling Green, Ohio
Role
21
Prochem Everest 650 HP. Very nice machine.
The back. Two vac and 3 solution reels. 600 ft total.
Through the side door.
Chemical Shelf. With the CMX 20 and RX 20
Fan shelf
Took these pics with my phone as I pulled in tonight before I prepped out.
The Magician
Very nice set up. How many hrs on the machine and what heat can you maintain? What do yo use the red gas cans for?
Hoody
Steven Hoodlebrink
Location
Bowling Green, Ohio
Role
21
The heat sticks around 200-210. I don't know exact but there are under 1000 hours on the machine. I believe its in the low 900's. The red gas cans are to fill the gas tank to the truckmount (you see it under the fan shelf in the last pic). The box truck is diesel and the TM is unleaded gas. We do A LOT of commercial carpet cleaning, anywhere from 20k-120k, so we keep extra gas on the truck to keep going. We've had it running for 8-10 hours straight already on long commercial jobs.
Jerry
What kind of flow are you running to maintain 200 degrees? or are you dual wanding?
Hoody
Steven Hoodlebrink
Location
Bowling Green, Ohio
Role
21
.08 flow(I would like to see .12) - When we dual wand it will drop a bit 180-200.
Hoody
Steven Hoodlebrink
Location
Bowling Green, Ohio
Role
21
This one isn't fully put together, but you get the idea.
:mrgreen:
The back.
The meat(blower just replaced, new one not pictured)
Cleaning the other night
GeneMiller
gene miller
Steve,
Nice set up. I hooked an extra tank right to the frame and use it for the machine. It hold's 30 gals. It's probably a lot safer then having the gas can inside.
Gene
Hoody
Steven Hoodlebrink
Location
Bowling Green, Ohio
Role
21
Yeah I wished that tank was just a little bit bigger.
That there is your Xentherm temp, which means your water was about 180º :lol:
Askal
RIP
Al
I did the same as Gene. Bought a used 30 gallon round tank from a salvage yard for 400 bucks and it just straps on. Much safer.
al
