- Feb 4, 2016
- Name
- Matt w.
You forgot to capitalize the D in dimwitand your's a dimwit if you think Water Clawing does any thing other than make piss stew.
Saiger" data-source="post: 4600254" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">We make and sell products but there are just sometime when the entire home is the litter box or pet pad (which I hate those things as it trains an animal it's OK to urinate and poo in the home)....
When that bad we still encourage replacement and will refuse and have people sign off.
Even with any product... Time will be needed for product to work and or get enough product to the problem. And the product is going to have to make contact with the Odor causing agent and problem. Removal of the Odor causing problem of course will make products work faster (Odor elimination basics)
I tell people....this isn't going to be a nuclear bomb but more of a time release bomb to take care of some problems.
And so to entertain Damon @Nomad74 ..... His favorite cat video
.I just want a pre spray for pet houses that works on all the carpet, but can be used to drench the peedles.
The problem with your situation is the home owner won’t let you pull the carpet and you don’t want to use a waterclaw.OK GrandMasterDogDick, tell us whats the scoop..
Larry you should travel around and be up on stage with other GURUS and preach to the other stupit carpet cleaners out there. Maybe charge them at the door about $10.95 for your secrets.
I’ll encap to that.you can lead a horse to water ...but sure as sheeit, there still too stoopit not to pee in it
.L.T.A.
.L.T.A.
