I had one yesterday where my solution line caused a mark in the Mop & Glow of the hardwood. I was able to rub and smear it away luckily.This all goes with my less is more mentality these days
less heat
less pressure
less high pH
If you turn the heat off the 870 what kind of temperatures do you seeI had one yesterday where my solution line cause a mark in the Mop & Glow of the hardwood. I was able to rub and smear it away luckily.
I've been like that since I got rid of my propane heaters. No difference in in the quality of my work.This all goes with my less is more mentality these days
less heat
less pressure
less high pH
Even with the heat off it gets to 190 ish and 200 on a hot day. I clean on low 98% of the time. All upholstery and wool is done with the heat off.If you turn the heat off the 870 what kind of temperatures do you see
less heat
less pressure
less high pH
While we're on the subject, have you ever not serviced your on board water softener and start telling a difference at the magical 50 hour mark?I've been like that since I got rid of my propane heaters. No difference in in the quality of my work.
The technician should know when to go all out hot or heat off. Using less of everything all the time isn't the answer to our businessThis all goes with my less is more mentality these days
less heat
less pressure
less high pH
I usually do the same my 870 on low is perfect for carpet I turn it off for upholstery or RugsEven with the heat off it gets to 190 ish and 200 on a hot day. I clean on low 98% of the time. All upholstery and wool is done with the heat off.
The new Flex IceI think if all you conscientious cleaners were buy a case of silver solution by the end of the case you're going to start thinking differently on just about everything when it comes to cleaning chemistry, I know I am..
I would not suggest running this as a rinse, moronThe new Flex Ice
What is it I’ll try itI think if all you conscientious cleaners were buy a case of silver solution by the end of the case you're going to start thinking differently on just about everything when it comes to cleaning chemistry, I know I am..
What is the new word we are supposed to use now that "retard" is no longer politically correct?I think if all you conscientious cleaners were buy a case of silver solution by the end of the case you're going to start thinking differently on just about everything when it comes to cleaning chemistry, I know I am..
We have natural soft water here.While we're on the subject, have you ever not serviced your on board water softener and start telling a difference at the magical 50 hour mark?
