waltmadd
Walter Madden
i have a white magic pro 1200 in a 2008 chevy express van. the transmission was recently replaced and now the 1200 is not recognizing the transmission in park.
Was the transmission control module reprogrammed properly?
Assuming the throttle control module (the part looking for the PARK signal from the TCU) is hooked up to the OBDII my guess would be it wasn't since that is where it gets the "park" signal.......I think
probably not any safety switch if you are not having problems with the van also
