Redneck relay repair....
  • Thread starter Carpet Cleaning Fool
  • Start date
Thought this was a neat trick.
Had a couple bad relays on my UD 1400. Luckily, a friend of mine knows a thing or two bout beer drinkin.. eh, i meant electrical.
Break open the relays, clean/adjust the contacts, seal it up with silicon and bailing wire... Good as new!
apparently nickey's goop comes in all flavors................
dgardner
I've done the same thing in a pinch. Good, yes. As new - probably not. Won't last nearly as long as new. A neat trick if the parts store is closed and you have to work tho...
