Environ HP
Environ HP is our exclusive green encapsulation cleaner that assists in making the HOS system complete. When you combine the Environ HP green cleaner with our exclusive orbital drive technology and bonnet pads you will attain tremendous soil extraction, fast dry times, no reoccurring stains, and a healthier environment for homes and commercial settings.
How Environ HP Works with Orbital Drive Technology
Most dry soil in a commercial or residential carpet can be readily removed by routine dry vacuuming. However, it’s the oily and sticky soils that attract and hold dry soil to the carpet fibers. The result is a dull, gray, and ugly appearance. To effectively remove these soil particles from the carpet fibers, the right amount agitation is needed. Orbital drive technology is the answer. The orbital drive of
the Orbot generates hundreds of small oscillations that spin at roughly 1725 revolutions per minute. This orbital drive pattern allows for all sides of the carpet fibers to be agitated and therefore all of the soil will be effectively removed from the carpet fiber. To ensure that the agitated soil will not stick to the carpet fiber again, a Polymer is needed to trap and encapsulate these soil particles. The polymer element in Environ HP will form distinct crystals when it dries. These crystals are the principle vehicles that stop wicking or the reoccurring of stains. They also enable the soil particles to be extracted through post-vacuuming, which keeps carpets cleaner for longer periods of time.
Retail value $168 plus shipping
Auction starts at $75 w/ $5 minimum increments
Auction ends Feb 10th at 6 PM
100% of proceeds go to the RMHC.
