Sally's/Vol 40/H2O2 - how do you use it?
Zee
I had a soldier bring a rug to the shop with a very dark yellow pee spot on it. Hand made Afgan, dark green, gold and black. I told him I would have to do drastic measures and he was ok with that. Sprayed 40 vol. on it and let it sit all day. Almost no change. It may have lightened a little. Then I hit it again with fresh 40 vol. followed by a spray of ammonia. Next morning, almost perfect. Did it again and by the end of day it was gone. Not 1 bit of color loss of the rug. No more stain magic for me. I've wasted so much money on that stuff and never got good results. That goes for stain1 and stain zone. Never have seen any carpet police in the area. I'll take my chances.
I think the color loss may not be the main issue when you do a treatment like you described. I would say the fiber breaking down from the repeated use of the ammonia and peroxide is what I would be worried about.
Maybe its ok right now but in a few weeks or months it could start falling apart. Hopefully it won't...otherwise you could have the soldier bring it with missing yarns in the area of the treatment.
Carpet police come after that soldier shoots you for damaging his rug! :p
Nice work Kevin!
great thread.
I use far less peroxide now that I'm all premium and shit.
(no mention of pet services on my web presence)
I just can't believe this site is still (mostly) working....although the other two locations are down
that isn't Richard in the pic so I assume it sold
Reactions: Mikey P
Meshell
Michelle
Role
Consumer / Homeowner
30
Lee;
The best stabilizers for peroxide are not just acids.
Low pH is required, but not the total answer.
Larry
I know this is a really old thread but....
What do you mean by acid?
Larry hasn't been back here ever since he sold out, but I think he was just trying to create a reason to buy his product over plainJane vol. 40 in the local Sally's store
I use both Sally's 40 volume as well as commercially prepared peroxide spotters. Sally's works well as a pretreatment for coffee or other organic stains but I like to rinse it out as it can cause damage in certain situations. I use Harvard's Stain Magic both as a pretreatment as well as a post treatment and find it works better than Sally's even though it's not as strong. Probably has to do with their formulation, surfactants, etc. One of my best products has been the 2 part products like Vanish, Eliminate, etc. Especially as a spray and walk away product. The ammonia boosts the action of the peroxide and becomes self neutralizing. Sally's is cheaper and does work but there are other products that work better. I believe Pro's Choice still sells 2 part oxidizers as well as 2 part reducers.
I’ve been using stain magic as well. I think it’s more like swimming pool peroxide because it does work better than Sally’s.
I have never had a problem with sallys 40 on anything. I haven't had the lightening problems mikey talked about. after trail and error I agree with mikey to make the 40 volume as strong as possible, mix 3 parts sallys with one part ammonia. any more ammonia than that and you just dilute the effect. the biggest thing that sucks about buying the stuff from sallys is how crappy the bottles are sealed they can actually leak if tipped over. the only time I haven't lightened the carpet is when I have put a wet towel over the spot and added heat. but that was already a go for broke situation and didn't matter. fels naptha and 40v is the last thing suppliers want you knowing about. another use for 40 volume is on ink stains that explode sometimes it will save you.
Probably a tiny hole to breathe because it can expand.
We just use Stain Magic, we used to buy peroxide for bio work from Sally's but now we use the Serum for that.
Went from 12% to 20% nice, where's my fingers?
I didn't need no stinking gloves hahaha
Johnny's Back
John LaRue
Role
25
I've been getting Harris brand gallons of 12% (40 volume) at Lowe's for $21.95. A lot cheaper, more convenient size, at least as good. Always in stock vs. Sallys spotty availability.
they live
Im going to look for this next trip there. The sallys has i think its phosphoric acid where the Harris doesnt.
Thank you for the tip.
Numero Uno
Caesar
1st Always wear gloves.
Get a metal air sprayer.
You inject them with a compressor no moving parts.
Either 12 ounce or 32 ounce container will work fine.
Check you pressure with a tire gauge.
Adjust as needed.
Triple rinse as well.
No o-rings just spout an trigger.
Back when I bought mine 15 to 30 dollars.
Still utilize 35 yrs later.
Treat them right , keep spray hole clean.
No need to poke at it an destroy tube.
Make sure she's clean.
Pore H202 through a screen.
Spray re rinse.
If need be compressor air the spout from outside to inside to dislodge a containament .
Works on solvents or water base as well.
Large size jacked with air.
Easily enough pressure to mist 10 to 12 feet of hall.
Regards.
