Sewage Water Extraction HELP !!
jerry ACC
Jerry Lightcap
The neighbor called Friday with a sewer line break in her basement. Plumber fixed it and the Insurance Company said to have the water extracted first and the'll come to view the scene.
I spent 3 hours there on Friday evening extracting the flooded basement.
My question is,
The insurance company is footing the bill, is there a fixed amount that is paid for such work ? Is there an Exactimate break down that I need to place on the invoice ? Or do I just charge to make my $100/hour ?
I don't do water damages normally, but it was next door and I used my pump out and ran straight into my sewer pipe.
Thanks in advance,
Jerry
Jerry what major city or town are you in or near? I can post or email you what Xactimate has for your area.
Be sure to bill for any necessary time to clean and disinfect your vac hoses, etc. There is more to a pump out job than just pumping.
Hoody
Steven Hoodlebrink
20
I hope you atleast wore tyvek and gloves, and even more so a respirator.
jerry ACC
Jerry Lightcap
Hey Chavez,
The closest big city is Philadelphia.
Thanks for any help.
Tank top, surf shorts, slippahs no count??? :lol: God I hate sewage work!
This is current for Philly as of July 10th.
You'll most likely come out better by the sq/ft for the cleanup. Look over the list and pick out the services you provided.
Don't forget to charge a decontamination/Cleanup fee for your equipment. :wink:
WTRACT Remove wet ceiling tile & drywall and bag for disposal SF $ 0.83
WTRACTA Remove wet ceiling tile & drywall, bag for disp. after hrs SF $ 1.20
WTRACTAS Remove wet ceiling tile w/staples - bag for disposal SF $ 0.63
WTRACTASA Remove wet ceiling tile w/staples, bag for disp. - aft hrs SF $ 0.92
WTRACTS Remove wet suspended ceiling tile and bag for disposal SF $ 0.32
WTRACTSA Remove wet susp. ceiling tile, bag for disp. - after hrs SF $ 0.44
WTRBAG Plastic bag - used for disposal of contaminated items EA $ 2.88
WTRBARR Containment Barrier/Airlock/Decon. Chamber SF $ 0.61
WTRBARRA Containment Barrier/Airlock/Decon. Chamber - after hours SF $ 0.89
WTRBARRP Containment Barrier - tension post - per day DA $ 3.30
WTRBARRZ Peel & seal zipper EA $ 11.07
WTRBARRZA Peel & seal zipper - after hours EA $ 12.34
WTRBASED Baseboard - Detach LF $ 0.92
WTRBASEDA Baseboard - Detach - after hours LF $ 1.37
WTRBASERS Baseboard - Detach and reset LF $ 1.52
WTRBIDITM Water Extraction & Remediation (Bid Item) EA $ 0.00
WTRBLK Block and pad furniture in room EA $ 36.59
WTRBLK< Block and pad furniture in room - Small amount EA $ 30.38
WTRBLK> Block and pad furniture in room - Large amount EA $ 49.86
WTRBLKA Block and pad furniture in room - after hours EA $ 55.08
WTRBLKA< Block and pad furniture in room - Small amount - after hrs EA $ 45.77
WTRBLKA> Block and pad furniture in room - Large amount - after hrs EA $ 75.04
WTRBLKHR Block and pad furniture - hourly charge HR $ 42.09
WTRBLKHRA Block and pad furniture - hourly charge - after hours HR $ 62.60
WTRCALC Calcium Chloride moisture test - per sample EA $ 66.17
WTRDHM Dehumidifier (per 24 hour period) - No monitoring EA $ 60.00
WTRDHM> Dehumidifier (per 24 hour period) - Large - No monitoring EA $ 71.00
WTRDHM>> Dehumidifier (per 24 hour period) - XLarge - No monitoring EA $ 101.25
WTRDHM>>> Dehumidifier (per 24 hour period) - XXLarge- No monitoring EA $ 133.00
WTRDHMAC Dehumidifier w/environmental control - per 24 hrs EA $ 123.25
WTRDHMD Dehumidifier (per 24 hour period) - Desiccant - No monit. EA $ 210.00
WTRDHMD< Dehumidifier (per 24 hr period) -Small-Desiccant-No monit. EA $ 110.00
WTRDHMD> Dehumidifier (per 24 hr period) -Large-Desiccant-No monit. EA $ 500.00
WTRDHMDT2K Trailer-mount dehumidifier - 2000 CFM- per 24 hr EA $ 950.00
WTRDHMDT3K Dehumidifier - Desiccant -3000-4000 CFM No monit.-per 24hr EA $ 1,246.00
WTRDHMDT5K Dehumidifier - Desiccant -4500-7500 CFM No monit.-per 24hr EA $ 1,551.00
WTRDHMDT9K Dehumidifier - Desiccant-8500-15000 CFM No monit.-per 24hr EA $ 2,536.00
WTRDRY Air mover (per 24 hour period) - No monitoring EA $ 25.94
WTRDRY+ Air mover axial fan (per 24 hour period) - No monitoring EA $ 29.58
WTRDRY++ Axial fan air mover - 1 HP (per 24 hr period)-No monit. EA $ 34.95
WTRDRYSA Air mover snout adapter 48" (per 24 hr period) - No monit. EA $ 10.00
WTRDRYW Tear out wet drywall, cleanup, bag for disposal SF $ 0.74
WTRDRYWA Tear out wet drywall, cleanup, bag - after business hours SF $ 1.02
WTRDRYWG Add-on cost for tearing out glued-on drywall SF $ 0.29
WTRDRYWGA Add-on cost for tearing out glued-on drywall - after hours SF $ 0.44
WTRDRYWLF Tear out wet drywall, cleanup, bag, per LF - up to 2' tall LF $ 2.53
WTRDRYWLFA Tear out wet drywall, cleanup, bag, per LF - 2' aft/hrs LF $ 3.62
WTRDUCTLF Ducting - lay-flat LF $ 0.27
WTREQ Equipment setup, take down, and monitoring (hourly charge) HR $ 40.89
WTREQA Equip. setup, take down & monitoring - after hrs HR $ 61.40
WTREQD Equipment decontamination charge - per piece of equipment EA $ 28.03
WTREQDH Equipment decontamination charge - HVY, per piece of equip EA $ 41.08
WTRESRV Emergency service call - after business hours EA $ 178.20
WTRESRVD Emergency service call - during business hours EA $ 118.80
WTREXT Water extraction from floor SF $ 0.49
WTREXT+ Water extraction from floor - Heavy SF $ 0.58
WTREXTA Water extraction from floor - after business hours SF $ 0.68
WTREXTA+ Water extraction from floor - Heavy - after business hours SF $ 0.82
WTREXTDMP Contaminated water dump fee - (Bid item) EA $ 0.00
WTREXTG Water extraction from floor - Category 2 water SF $ 0.75
WTREXTG+ Water extraction from floor - Category 2 water - Heavy SF $ 0.90
WTREXTGA Water extract from floor - Cat 2 water - aft business hrs SF $ 1.09
WTREXTGA+ Water extract from floor - Cat 2 water -Heavy -aft bus hrs SF $ 1.30
WTREXTS Water extraction from floor - Category 3 water SF $ 1.21
WTREXTS+ Water extraction from floor - Category 3 water - Heavy SF $ 1.44
WTREXTSA Water extract from floor - Cat 3 water - aft business hrs SF $ 1.69
WTREXTSA+ Water extract from floor - Cat 3 water -Heavy -aft bus hrs SF $ 2.00
WTREXTW Water extraction from floor - Weight-assisted SF $ 0.91
WTREXTWA Water extraction floor - Weight-assisted - after bus. hrs. SF $ 1.53
WTREXTWP Pumping of standing Category 3 water GL $ 0.65
WTREXTWPA Pumping of standing Category 3 water - after business hrs. GL $ 0.99
WTREXTWPC 2" Submersible pump with hose (per 24 hour period) DA $ 144.03
WTRFCC Tear out wet non-salvageable carpet, cut & bag for disp. SF $ 0.40
WTRFCCA Tear out wet non-salvage cpt, cut/bag - after business hrs SF $ 0.58
WTRFCCGD Tear out wet non-salvageable glue down carpet, cut/bag SF $ 0.69
WTRFCCGDA Tear out wet non-salv. gluedn. cpt, cut/bag- aft. bus. hrs SF $ 1.00
WTRFCCGDN Tear out wet non-salvageable glue down carpet, no bagging SF $ 0.54
WTRFCCGDNA Tear out wet non-salv. gluedn. cpt, no bag - aft. bus. hrs SF $ 0.81
WTRFCCGDS Tear out wet non-salv. gluedn. cpt, cut/bag - Cat 3 water SF $ 1.00
WTRFCCGDSA Tear out wet non-salv.gluedn.cpt,cut/bg-Cat 3 wtr-aft. hrs SF $ 1.48
WTRFCCGSN Tear out wet non-salv. glue down cpt, no bag - Cat 3 water SF $ 0.81
WTRFCCGSNA Tear out wet non-salv.gluedn.cpt,no bag-Cat 3 wtr-aft. hrs SF $ 1.20
WTRFCCN Tear out wet non-salvageable carpet, no bagging SF $ 0.23
WTRFCCNA Tear out wet non-salvage carpet, no bag-after business hrs SF $ 0.34
WTRFCCS Tear out wet non-salvageable carpet, cut/bag - Cat 3 water SF $ 0.58
WTRFCCSA Tear out wet non-salv. cpt, cut/bag-Cat 3 wtr-aft bus. hrs SF $ 0.84
WTRFCCSN Tear out wet non-salvageable carpet, no bag - Cat 3 water SF $ 0.34
WTRFCCSNA Tear out wet non-salv. cpt, no bag -Cat 3 wtr-aft bus. hrs SF $ 0.51
WTRFCV Tear out non-salvageable vinyl, cut & bag for disposal SF $ 0.96
WTRFCVA Tear out non-salvageable vinyl, cut & bag - after hrs SF $ 1.41
WTRFCVL Tear out non-salv vinyl, cut & bag - additional layer SF $ 0.33
WTRFCVLA Tear out non-salv vinyl, cut & bag - add'l layer after hrs SF $ 0.48
WTRFCVS Tear out non-salv vinyl, cut & bag - Category 3 water SF $ 1.41
WTRFCVSA Tear out non-salv vinyl, cut & bag - Cat 3 water-after hrs SF $ 2.16
WTRFCVSL Tear out non-salv vinyl, cut & bag - Cat 3 wtr - add'l lyr SF $ 0.48
WTRFCVSLA Tear out non-salv vinyl, cut & bag - Cat 3 add'l lyr a/hrs SF $ 0.74
WTRFCVT Tear out non-salvageable vinyl tile, cut & bag for disp. SF $ 1.10
WTRFCVTA Tear out non-salv. vinyl tile, cut & bag for disp. Aft hrs SF $ 1.63
WTRFCVUV Tear out non-salv. vinyl & underlay, cut & bag for disp. SF $ 1.31
WTRFCVUVA Tear out vinyl & underlay, bag for disp. - after hours SF $ 1.93
WTRFCVUVS Tear out vinyl & underlay, bag for disp. - Cat 3 water SF $ 1.93
WTRFCVUVSA Tear out vinyl & underlay & bag. - Cat 3 water - after hrs SF $ 2.85
WTRFCW Tear out non-salv wood flr & bag for disposal SF $ 2.47
WTRFCWA Tear out non-salv wood flr & bag - after hrs SF $ 3.61
WTRFCWL Tear out non-salv laminate floor & bag for disposal SF $ 1.77
WTRFCWLA Tear out non-salv laminate floor & bag - after hrs SF $ 2.61
WTRFCWLS Tear out non-salv laminate floor & bag - Category 3 water SF $ 2.61
WTRFCWLSA Tear out non-salv lam. flr & bag- Category 3 water-aft hrs SF $ 4.04
WTRFCWS Tear out non-salv wood floor & bag - Category 3 water SF $ 3.61
WTRFCWSA Tear out non-salv wood floor & bag - Cat 3 water - aft hrs SF $ 5.60
WTRFCWSC Screen wood floor SF $ 0.51
WTRFHEPA Add for HEPA filter (for negative air exhaust fan) EA $ 160.33
WTRFHEPA< Add for HEPA filter (for canister/backpack vacuums) EA $ 39.08
WTRFHEPA<< Add for HEPA filter (for upright vacuums) EA $ 25.03
WTRFHEPA> Add for HEPA filter (for neg. air machine/vacuum - Large) EA $ 215.08
WTRFLVAP Carbon vapor filter (for air scrubber) - 16" x 16" EA $ 69.08
WTRFLVAP> Carbon vapor filter (for air scrubber) - 24" x 24" EA $ 99.08
WTRFURN Drying furnace - ind. fired heater w/ducting - 85 kBtuh DA $ 160.00
WTRFURN17 Drying furnace - ind. fired heater w/ducting - 170 kBtuh DA $ 460.00
WTRFURN25 Drying furnace - ind. fired heater w/ducting - 250 kBtuh DA $ 575.00
WTRFURN40 Drying furnace - ind. fired heater w/ducting - 400 kBtuh DA $ 830.00
WTRGRM Apply anti-microbial agent SF $ 0.22
WTRGRMA Apply anti-microbial agent - after hours SF $ 0.32
WTRGRMB Apply plant-based anti-microbial agent SF $ 0.24
WTRGRMBA Apply plant-based anti-microbial agent - after hours SF $ 0.35
WTRHBAG Plastic bag - for hazardous material cleanup - Medium EA $ 2.35
WTRHBAG< Plastic bag - for hazardous material cleanup - Small EA $ 1.14
WTRHBAG> Plastic bag - for hazardous material cleanup - Large EA $ 3.08
WTRHBOX Box and liner - for hazardous material cleanup - Medium EA $ 5.60
WTRHBOX< Box and liner - for hazardous material cleanup - Small EA $ 2.81
WTRHBOX> Box and liner - for hazardous material cleanup - Large EA $ 9.07
WTRHC14 Plastic container - hazardous material cleanup - 14 gl EA $ 32.07
WTRHC30 Plastic container - hazardous material cleanup - 30 gl EA $ 45.68
WTRHC60 Plastic container - hazardous material cleanup - 60 gl EA $ 72.00
WTRHCON Plastic container - hazardous material - Medium EA $ 8.57
WTRHCON< Plastic container - hazardous material cleanup - Small EA $ 5.70
WTRHCON> Plastic container - hazardous material cleanup - Large EA $ 13.42
WTRHDRY Hang dry carpet in plant SF $ 0.42
WTRHDRY+ Hang dry custom oriental rug in plant SF $ 0.65
WTRHEAT Heat drying - hydronic boiler/power unit - 200 kBtu DA $ 600.00
WTRHEAT> Heat drying - hydronic boiler/power unit - 250 kBtu DA $ 900.00
WTRHEATA Heat drying - ducted air - 200 kBtu - 2300+ cfm DA $ 1,375.00
WTRHEATA> Heat drying - ducted air - 400 kBtu - 5200+ cfm DA $ 2,200.00
WTRHEATX Heat drying - thermal exchanger with air mover - 50 kBtu DA $ 205.68
WTRHEATX> Heat drying - thermal exchanger with air mover - 80 kBtu DA $ 300.00
WTRHEPAVAC HEPA Vacuuming - hourly charge HR $ 44.02
WTRHEPAVAL HEPA Vacuuming - Light - (PER SF) SF $ 0.35
WTRHEPAVAS HEPA Vacuuming - Detailed - (PER SF) SF $ 0.51
WTRHTAM Heat drying - thermal air mover - Electric DA $ 200.00
WTRINS Tear out and bag wet insulation SF $ 0.55
WTRINSA Tear out and bag wet insulation - after hours SF $ 0.80
WTRINSC Tear out and bag wet insulation in crawl space SF $ 1.04
WTRINSCA Tear out and bag wet insulation in crawl space - after hrs SF $ 1.55
WTRLAB Water Extraction & Remediation Technician - per hour HR $ 40.89
WTRLABA Water Extraction & Remediation Technician - after hours HR $ 61.40
WTRLABC Cleaning Technician - per hour HR $ 30.33
WTRLABCA Cleaning Technician - after hours HR $ 45.54
WTRLABS Cleaning & Remediation - Supervisory - per hr HR $ 44.55
WTRLABSA Cleaning & Remediation - Supervisory - after hrs. HR $ 66.89
WTRLIFT Lift carpet for drying SF $ 0.30
WTRLIFTA Lift carpet for drying - after hours SF $ 0.42
WTRMASKFL Floor protection - self-adhesive plastic film SF $ 0.41
WTRMASKFLA Floor protection - self-adhesive plastic film - after hrs SF $ 0.54
WTRMASKFLP Floor protection - drop cloth - skid resistant, leak proof SF $ 0.69
WTRMASKFP+ Floor prot. - cloth - skid resist, leak proof, cleanable SF $ 0.72
WTRMASKFPB Floor protection - drop cloth - skid resistant, breathable SF $ 0.87
WTRMN Service - Minimum charge EA $ 125.00
WTRMR Per job charge for 3rd party monitoring/review (Bid item) EA $ 0.00
WTRNAFAN Negative air fan/Air scrubber (24 hr period) - No monit. DA $ 71.73
WTRNAFAN> Neg. air fan/Air scrub.-Large (per 24 hr period)-No monit. DA $ 121.73
WTRPAD Tear out wet carpet pad and bag for disposal SF $ 0.38
WTRPADA Tear out wet carpet pad, cut/bag - after business hours SF $ 0.55
WTRPADN Tear out wet carpet pad, no bagging SF $ 0.10
WTRPADNA Tear out wet carpet pad, no bagging - after business hours SF $ 0.16
WTRPADS Tear out wet carpet pad, cut/bag - Category 3 water SF $ 0.55
WTRPADSA Tear out wet carpet pad, cut/bag - Cat 3 wtr - aft.bus.hrs SF $ 0.80
WTRPADSN Tear out wet carpet pad, no bagging - Category 3 water SF $ 0.16
WTRPADSNA Tear out wet carpet pad, no bag - Cat 3 wtr - aft.bus.hrs SF $ 0.25
WTRPLYTK Tear out toe kick and bag for disposal LF $ 2.22
WTRPLYTKA Tear out toe kick and bag for disposal - after bus. hours LF $ 3.18
WTRPNL Tear out wet paneling, bag for disposal SF $ 0.44
WTRPNLA Tear out wet paneling, bag for disposal - after hours SF $ 0.62
WTRPOWD Power distribution box DA $ 26.92
WTRPPE Add for personal protective equipment (hazardous cleanup) EA $ 10.32
WTRPPE+ Add for personal protective equipment - Heavy duty EA $ 17.03
WTRPPEB Boots - waterproof latex - Disposable (per pair) EA $ 6.84
WTRPPEE Eye protection - plastic goggles - Disposable EA $ 4.96
WTRPPEG Personal protective gloves - Disposable (per pair) EA $ 0.49
WTRPPEG+ Personal protective gloves - Heavy duty (per pair) EA $ 2.92
WTRPPER Disposable rain suit EA $ 9.00
WTRPPERC Respirator cartridge - HEPA only (per pair) EA $ 9.32
WTRPPERCM Respirator cartridge - HEPA & vapor & gas (per pair) EA $ 21.35
WTRPPERCP PAPR cartridge - HEPA only (single cartridge) EA $ 14.64
WTRPPERCPM PAPR cartridge - HEPA & vapor & gas (single cartridge) EA $ 30.86
WTRPPERCPV PAPR cartridge - vapor only (single cartridge) EA $ 22.19
WTRPPERCV Respirator cartridge - organic vapor & acid gas (per pair) EA $ 10.71
WTRPPERF Respirator - Full face - multi-purpose resp. (per day) DA $ 7.61
WTRPPERH Respirator - Half face - multi-purpose resp. (per day) DA $ 1.67
WTRPPPAPR Powered Air-Purifying Respirator (PAPR) - per day DA $ 73.25
WTRPPSAR Supply Air Respirator (SAR) - per day DA $ 61.25
WTRPROT Protect - Cover with plastic SF $ 0.24
WTRPROTA Protect - Cover with plastic - after hours SF $ 0.30
WTRRM Remote monitoring sys. w/up to 10 sensors (per 24 hr prd) DA $ 55.00
WTRRMG Remote monitoring - additional gateway (per 24 hr period) DA $ 30.00
WTRRMS Remote monitoring - each additional sensor (per 24 hr prd) DA $ 3.00
WTRSANDF Sand exposed framing - Floor SF $ 1.49
WTRSANDW Sand exposed framing - Walls SF $ 0.81
WTRTACK Tear out tackless strip and bag for disposal LF $ 0.68
WTRTACKA Tear out tackless strip and bag for disposal - after hours LF $ 1.21
WTRTACKG Tackless strip guard LF $ 0.40
WTRTACKGA Tackless strip guard - after hours LF $ 0.54
WTRTEST Contamination - air or surface testing & lab analysis EA $ 102.70
WTRTEST+ Contamination - pre & post test - full service (Bid item) EA $ 0.00
WTRTESTATP Contamination - on-site ATP testing EA $ 21.60
WTRTHERM Thermal imaging - (Bid item) EA $ 0.00
WTRTRAN Transport carpet for drying SF $ 0.26
WTRTRI Tear out trim/base LF $ 0.34
WTRTRIA Tear out trim/base - after business hours LF $ 0.51
WTRTRIM Tear out trim/base and bag for disposal LF $ 0.68
WTRTRIMA Tear out trim/base and bag for disposal - after bus. hours LF $ 0.94
WTRTRIMT Add-on for tearing out trim/base from tile/grout LF $ 0.44
WTRTRIMTA Add-on for tear out trim/base from tile/grout - after hrs LF $ 0.67
WTRULAY Tear out non-salv underlayment & bag for disposal SF $ 1.09
WTRULAYA Tear out non-salv underlayment & bag - after business hrs SF $ 1.60
WTRULAYS Tear out non-salv underlayment & bag - Category 3 water SF $ 1.60
WTRULAYSA Tear out non-salv underlayment & bag - Cat 3 wtr - aft.hrs SF $ 2.37
WTRWALL Wall cavity drying-Inj. type (per 24 hr period) No monit. DA $ 140.00
WTRWALLD Wall cavity drying-Dctd type (per 24 hr period) No monit. DA $ 80.00
WTRWALLF Fill holes created by wall cavity drying EA $ 1.01
WTRWALLH Drill holes for wall cavity drying EA $ 0.41
WTRWALLHA Drill holes for wall cavity drying - After hrs EA $ 0.57
WTRWFD Wood floor drying-Dctd type (per 24 hour period) No monit. DA $ 95.00
WTRWFDAD Wood flr drying add-on kit-Dctd(per 24 hr period) No monit DA $ 50.00
WTRWFI Wood floor drying-Inj. type (per 24 hour period) No monit. DA $ 180.00
jerry ACC
Jerry Lightcap
Thanks Richard,
Here's what I figured.
WTREXTS-Water Extraction from floor Category 3- 1.21/Sqft x 135 Sqft = $163.35
WTRESRV-Emergency Service Call - After Hours = $178.20
WTREQD - Equipment Decon.-$28.03 Per Unit (x3) 2 Hoses 50'/ Waterclaw = $84.09
WTRLABCA-Cleaning Tecnician - After Hours- $45.54/HR (x3) = $136.62
Total_______________________
$562.26
WOW !! Does that seem right.
I was only going to charge $275, but if insurance is picking this up is this what I shoud bill ?
They were already given the go ahead with remediation and drying and such, and the insurance wrote a heck of alot more off than I thought they would, like the furniture not even touched in the next room over.
Jerry did you use any PPE, gloves, mask, tyvek, 6-mil bags? All those would be additional. Did you wash it down? We would normally pressure wash and then later come back for a detail clean with turbo/SX-12 tool.
Was it after hours? Then use this one, your other line items say after hours.
instead of the water extraction you have listed.
We charge a flat rate of Equipment decontamination $125.00. (Cleaning all tools used, including TM tank and hoses)
It may seem like a lot for three hours work but that is actually pretty small as Sewage losses go. We often send 3-4 guys and they may spend 6-8 hours there and leave HEPA air scrubber and airmovers and dehumidifiers for a day.
Many times we fill a dumpster with all the contaminated debris and drywall.
jerry ACC
Jerry Lightcap
Thanks Richard,
I did not wear any PPE, I know I should but I didn't.
All I did was pump out the water and use the large waterclaw on all of the affected carpet.
I could not do any more as the insurance company was coming the next morning to access the damage.
She has already hired a restoration company to do the rest, as I'm not certified to do the indepth work, and did not want to take on the responsibility.
Thanks again,
Jerry
