Some help please on a TM problem
kevinj6121
kevin
I have a boxer 318 which i bought brand new, its been a great machine for me. Yesterday i was doing some uppholstery and the machine was struggling to stay running for a bit then shut itself off. I checked my oil because i know i have some minor oil leaks and it was low, so i added some and now it stays running but doesn’t throttle up to full speed and if i hold my hand over the vacuum hose it losses rpms which it never did before, i have checked the air filter and it is good, i’m thinking maybe a fuel filter or fuel pump problem which i’ll check the fuel filter today, don’t know how i’d check the fuel pump.
Anybody have any suggestions to help me
The Bull
It could be several things, 1, it could be fuel related. When running the unit with a load, pull the choke out slightly, does the machine attempt to recover or start to die? 2nd Could it possibly be running on one cylinder? I suggest calling 425775-7276 and ask for Dennis Russel. He is the best and can walk you through most scenarios.
kevinj6121
kevin
I haven't tried what you suggested but will and thanks for the phone number for Dennis
Reactions: The Bull
kevinj6121
kevin
As recommended above.
Also:
When did you last change spark plugs?
Actually i haven't ever changed the spark plugs but i did take them out to check them, there are two, there was carbon on them so i took a wire brush to them to clean them off and put them them back but it made no difference, i will go get two new ones tomorrow and just change them anyway though
kevinj6121
kevin
I will change the fuel filter tomorrow and also change my spark plugs and if still not better i can change the fuel pump but i'll have to order that, the fuel filter i can get locally
You can buy your fuel pump locally too. Just get a 3.5-7 psi fuel pump at any auto parts store
Doug B
Might not be the same problem, but my Legend with a Kohler engine was "bogging" and "stumbling" and sometimes stalling under load. Seemed to run fine with no load. After some testing, the mechanic I took it to said it was a cracked ignition coil. Had them both replaced and it was fine after that.
kevinj6121
kevin
thanks i'll keep that in mind if after replacing both spark plugs, fuel filter and pump if that doesn't fix it
I had the same problem on a Honda engine. Replacing the coils solved the problem.
kevinj6121
kevin
I changed my spark plugs and the fuel filter, air filter is also clean engine runs fine but still bogs down when i hold my hand over the vacuum hose and seal it off, guess my next step would be changing the fuel pump itself
Lubricate your vac relief spring valve on the recovery tank to see if it's working properly. It might not be opening up, which is showing those symptoms
and look at what the hg's are set at while you're doing it
KevinD
Kevin Dumas
Unless you just want to throw parts at it there are testing procedures for fuel pumps and coils.
Along with a compression test to rule out a burnt valve.
kevinj6121
kevin
Well i've only changed the spark plugs and the fuel filter and made sure the air filter is clean, so not much money spent there, i am going to take it in for further diagnosis only problem is closest place is just under 3 hours away but i gotta do what i gotta do i guess.
they live
Coil or you need a new carb is my guess.
Im surprised you can't find a small engine repair shop nearby.
scotty747
Some small fuel pumps have a filter screwed into it. Pull the fuel line and turn the key. If it shoots out its good, but may be crapping out when getting hot. Does it bog down the same when cold vs hot?
kevinj6121
kevin
Well i have my truck in the shop now, dropped it off yesterday, had to drive 3.5 hours away they said that my valves need to be adjusted as they are a lot off then what they should be, they also said one of the adjusting bolts was cracked and broke while trying to get it out, they didn’t have a replacement so i probably wont’t have my truck back till monday but said that my issue can be caused by the valves being out of adjustment, so i hope this solves my problem, they said everything else so far checks out good, so got my fingers crossed
Does your model have the Briggs engine? If I remember correctly, I think it says something about adjusting the valves every 300hrs?? Can someone confirm that number? I remember having to do it very frequently, which is why I think Hydramaster is lazy, putting a Briggs product on our machines. That should hardly ever be needed with the technology of the other types of engines out there
Briggs belongs on only 2 types of machines: Pushmower, and a go-cart
kevinj6121
kevin
They told me at the shop the valves should be adjusted every 500 hours
they live
My power washer has the vangard and its loud compared to the Honda.
KevinD
Kevin Dumas
Just hope it didn't burn one or ruin the seat or it will be longer than monday.
kevinj6121
kevin
Well the final verdict on my boxer 318 is that it needs a new motor, they said a valve adjustment would fix it but apparently that did not take care of my problem and they told me the camshaft was very loose and wobbly and they con’t fix it so i am just putting a new motor in it
  • Sad
Reactions: Kenny Hayes
Never heard of a "loose wobbly cam shaft" before. Ive heard of spun bearings, rounded lobes, warn out thrust bearing but never loose wobbly cam shaft. I would question more before throwing out the motor cam moving in and out would suggest a thrust bearing up and down cam bearings possibly cam too bearings should only be 50 or so bucks+labor and a complete camshaft 100-150.00. Might as well replace your "high volume kooparater" while you're at it( that part connects to the throttle waddle on a ducks ass. ) not to be too sarcastic . But it sounds to me like this company is like the transmission shop in my town. For a 30.00 part and 250.00 labor they told me i needed a new transmission 3780.00+labor
kevinj6121
kevin
i do believe thats what he said
I mention to the guy when i first took it in about just replacing the motor but he said he didn't think i needed a new motor but turns out i do, oh well
Misery loves company! A drive wheel for one of my Chariot scrubbers wound up costing $1400 part and labor. Sorry Kevin
