- Apr 17, 2009
- Name
- Kenny Hayes
I have a corded Dyson for my house. It’s 7-8 yrs old minimum. Course I use the Dyson 7 daily and take it with me if doing some sort of jani work.
Get the warranty and never pay again. And Matt, stop being an idiot. I’ve used the commercial vacs and they break just as fast as any other vac. The problem is it takes forever to get replacement parts and they are not easy to fix. I know, I’ve gone through a few. Its much easier to just drop into Best Buy and get a new one covered under the 2 year extended warranty.Only reason I stopped using Dyson vacs is because they became so expensive and my local Sears store ( which was a service point) went out of business.
But I was sure happy to find Sharks.
Well at least you'll be vacuuming less because you aren't going to be able to fit that ball under anything.Get the warranty and never pay again. And Matt, stop being an idiot. I’ve used the commercial vacs and they break just as fast as any other vac. The problem is it takes forever to get replacement parts and they are not easy to fix. I know, I’ve gone through a few. Its much easier to just drop in to Best Buy and get a new one covered under the 2 year extended warranty.
I finally gave up on the sharks due to the beater bar motor.
My last Dyson would overheat and turn off. Hoping with my new Animal 3 i have better luck. I did notice that the brush head is much heaver than the Shark. Maybe that translates to a more powerful motor.
Oreck, takes a licking and keeps on liftingSee, I knew he would pop his head out!! Ok, all your items you endorse, from your glides to your watches, and everything in between,
the Oreck has to be at the bottom of the pile. I don’t know of anything even close![]()
And sometimes, Everybody hurts.Everything works, until it doesn't..![]()
